I have read every forum I could find and didn't see this exact issue replicated. I have a KitchenAid Side by Side Refridgerator (KSRG25FKBT04) and the Damper (difuser?) between the fridge and the freezeer slowly ices up. The fridge warms up and the freezer ices up.
I have thawed the whole unit with a blow dryer on a couple of occassions and it always closes back up. I have dis-assembled the unit and taken both the fridge and freezer side completely apart. There are no drainage tubes or anything to clean out, so I don't know the source of the water and ice. The damper itself is just a mechanical unit (opened and shut by adjusting the Freezer warmer or cooler setting) that does not appear to have any specific electronics, so I don't really get how replacing that unit will help. Please indicate action you would recommend I take. Thanks |
Your correct, your air diffuser doesn't have any electronics in it like other models do, so if its freezing up that always tells me you have an air leak, check both door gaskets for proper sealing, make sure you have no rips in your door gaskets. The warm kitchen air always goes to the coldest source first, thats why its going to your air diffuser, and causing the condensation and the ice/frost clog. Jake
There are no visible rips or gaps in the gaskets on either the fridge or freezer side. Is there a way to pressure test for leaks?
Is it most likely a leak on the fridge side? Any other possible causes you can think of? Thanks very much for the help. |
When did this start happening? How warm/hot is your kitchen? During these hot summer months I see this issue happen alot, if you have no air leaks, then try to keep the doors closed as much as possible. Quote:
Also while your in the freezer section, take some food out and look at your back panel inside your freezer, and see if there's any frost build-up on that panel. Jake
set freezer at mid temp, same for fridge side. how many and how long do peoples stand with the door open and think of what to eat? how much warm food is put in- major groceries warm up fridge and cause condensation/ice.
LinkBack to this Thread: http://www.applianceblog.com/mainforums/kitchenaid/13795-another-kitchenaid-warm-fridge-cold-freezer-issue.html
| Fridge Not Cold, Freezer Working - KitchenAid Superba - ApplianceBlog.com - Appliance Repair Forums | This thread | Refback | September 11th, 2009 08:27 PM | |
| GE Profile Fridge. Cold Freezer. Warm Fridge | rcdr | GE/Hotpoint | 3 | April 3rd, 2008 08:27 PM |
| KitchenAid KSRS25ILWH01 Refrig warm, Freezer cold | baileyshbr | KitchenAid | 6 | March 19th, 2008 06:04 AM |
| Kitchenaid KSCS25FJSS00 - cold freezer, warm fridge | lloydbishop | KitchenAid | 6 | March 18th, 2008 10:21 AM |
| Whirlpool Fridge \ Freezer cold Fridge warm | Harrison | Whirlpool | 2 | December 6th, 2007 11:45 PM |
| Kenmore Cold Freezer - Warm fridge Frost free failure | rkgrp | Sears Kenmore | 4 | April 4th, 2006 11:52 AM |
