Old September 13th, 2008, 02:28 PM
NathanH is on a distinguished road
Default [FIXED] KUDS01DJSS0 Rinse Only light blinking
I've read many posts about this problem (enough to know it's pretty common with this model.) Most of the solutions I've read involve replacing the touchpad/control panel. However, I've also seen mentioned replacing the electronic control assembly. Since both of these items are fairly expensive, I don't want to replace them both if I don't have to.
So, here's my dishwasher's symptoms. It started with realizing the light was blinking non-stop and the machine would not respond. After reading some blogs, I opened the control panel, and after simply unplugging the wire ribbon from the control assembly and plugging it back in, it seemed to "reset" and would run through a whole cycle. Then, it started to stop in the middle of a cycle (at ~ 42 min). Manipulating the wire ribbon will temporarily reset it. But, then the blinking starts again. At this point, I'm just happy to make it to the "dry" cycle.
Any ideas about where to start would be much appreciated.
Old September 13th, 2008, 09:14 PM
It sounds like its just your ribbon cable that needs to be replaced.
Here's the ribbon cable for your model you can order:
Manufacturer's Number: 8269202
icon
icon
icon8269202
NathanH (September 14th, 2008)
Old September 22nd, 2008, 08:07 PM
Default It's working again!
Hello,
I liked the idea of just buying the ribbon cable, but I feared continuing to have the same problem. Since a new touchpad/control panel includes the ribbon cable, I ordered a gray one to match from Repair Clinic.com (item # 922872 / part # 8531013).
Installed it tonight, and washed my first load of dishes non-stop since this all started about a month ago. Many thanks to this website. What a great source of information!
NathanH
Old September 22nd, 2008, 08:32 PM
Excellent NathanH, good job fixing it.
Kenmore 665.13692K600 - Quick Rinse Light Blinking Cero21 Sears Kenmore 7 October 9th, 2009 08:16 PM
whirlpool gold gu1500xtlb2 blinking rinse light davis1413 Whirlpool 7 September 7th, 2008 05:29 PM
Kenmore 665 Normal Wash Red light blinking javaid Sears Kenmore 3 June 19th, 2007 08:10 AM
KUDS01DLSS0 rinse light blinking Jeff N KitchenAid 6 June 14th, 2007 07:56 PM
Model KUDS01DJSS0 Flashing rinse only light Toddc KitchenAid 1 October 24th, 2006 08:41 PM
