Old October 7th, 2008, 02:02 PM
indyanne is on a distinguished road
Default KitchenAid KSCS23INSS00 Ice Maker Malfunctioning
I've been troubleshooting my KSCS23INSS00 ice maker. I have conducted several tests of the optics. I have used a jumper at T and H on the cam timer module to start the harvest several times.
The optics test fine every time. The problem seems to be with the cam timer module.
The ejector can be set back to 2:00 home position using the jumper, and the mold fills up with water just fine on this manual reset. But, that's it -- the ejector never returns back to 2:00 on its own.
The cam timer module and new ejector set arrived today and I have replaced these parts. I am waiting now to see if this fixes the problem.
The ejector is sitting on 2:00, but there is no water in the ice trough, of course.
Question: should I conduct a manual reset with the jumper to get the cycle going, or, as I have done, just plug the module in and let it go on its own?
Anne
Old October 7th, 2008, 04:56 PM
Hi Anne,
The water should fill the ice maker before it gets to the 2:00 home position, when you say its filling with water on manual reset, what does that mean? When is it filling with water?
Old October 8th, 2008, 07:12 AM
I am talking about the original module, when the jumper is used, will go through a fill cycle of water into the mold, and the ejector will revolve into the home position, but when the time comes to dump the ice, the ejector will not complete the cycle around. The water melts in the mold and the ejector becomes frozen into the ice.
When I took the original module out, replaced with the new one, I found that one of the tabs holding the ejector arm, the end with the "D" profile, into the module was broken. I'll try to attach a photo. This tells me that somehow, the ejector is not making it back into the home position.
So, with the new module in place, should I do anything to get the cycle going? Should I use the jumper to initiate the first harvest cycle, to prompt the system to fill the mold with water? Or, will the thermostat -- without using the jumper -- start the cycle?
I regret to say that I put the new module and ejector and stripper pieces on the ice maker, plugged in the wiring, and nothing has happened.
I tried the jumper sequence indicated in the service manual, but the harvest cycle did not begin.
I now have the ice maker out, planning to start over. First, I want to test the power going to each of the circuits on the module. I am using the wiring diagram that I found on a sheet that was folded into a tiny little wad in the bottom of the fridge when I removed the grille to clean the coils with the vacuum cleaner and brush.
I am not against calling a service rep, but I am averse to paying the labor cost and possibly risk someone coming who will simply suggest a very expensive repair option that might not be necessary.
I hope I will not damage the fridge in the process of these trouble-shooting efforts.
Anne
Originally Posted by Jake View Post
Hi Anne,
Old October 8th, 2008, 07:41 AM
I have posted some photos in my Picasa albums. This link should work:
http://picasaweb.google.com/Indy.AGM...81135AM?pli=1#
Note that the tab is broken and the part that holds the "D" end of the ejector arm is cracked.
Anne
Anne
Old October 8th, 2008, 08:27 AM
Ok, I see it.
So let me get this straight, the new ice maker module came with the gear tab broken? Were did you buy the new ice maker module? Thats the problem, the new ice maker module shouldn't come with the gear tab broken, send it back and request another one.
Old October 8th, 2008, 08:35 AM
Wait, I'm getting confused from the old module to the new one. Lets forget about the old module, I re-read your post and looks like the new module is fine.
Yes, thats what I do, but remember before you jump the T & H you need to unplug your refrigerator for about 5 minutes first!
Then plug it in, then jump T & H while holding your freezer light switch in and also while holding the flapper on the left side wall closed, you can use tape to hold it for you.
Then leave the jumper wire in T & H for about 15-20 seconds, after you see the gear moving.
Give it up to 90 seconds for the gear to start moving once you put the jumper wire in T & H.
Old October 8th, 2008, 10:44 AM
More issues:
Here are the steps I took:
--unplug the fridge
--remove the ice maker (this lets the module and moving parts thaw)
--wait five minutes
--put the jumper in T and H
--reinstall the ice maker (I'm not clear here -- leave the door open?)
--plug the fridge back in
--hold the IR flap against the side and hold the door light switch closed, simultaneously
--Wait for the module gear to begin moving (harvest cycle begins), wait as long as 90 seconds for the harvest cycle to begin.
--Close the door. Problem is, I wait so long with the door open that the freezer temp gets too high to make ice, so I remove the jumper, close the door, and log back into this thread while the freezer cools back down.
Help! The gear is not moving at all.
I unplugged the fridge for five seconds, then plugged in and waited five seconds. Then I opened the freezer door and checked the LED code. I saw the two two-second lights followed by one second off, then three pulses. The service manual, page 5-7 indicates the optics and relay are ok, but the ice maker is not being sensed, or will not operate (no kidding!).
--Check the bail arm switch to make sure it is OK (my model does not use the bail arm, but the switch on the module that would operate the bail on and off is not engaged on its little parking spot, little round dot thingy on the module. I mean, the switch can be set manually to the bail arm off position, but I don't do that, I leave it alone, to be engaged by the cam mechanism on the module.)
--Check the ice maker circuit and the connections back to the receiver board and neutral. (I'm able to check these circuits. I don't know what the neutral is -- is this the neutral electrical wire?)
--Check the ice maker components.
What could be going on here? Apparently, the problem with the ice maker was mechanical. The sleeve on the cam motor and the motor cam tab was broken. Why would there be an electrical problem if the break was simply mechanical? Broken original module out, new unbroken module in, fixed, no? No! Now it appears the ice maker is not being recognized despite the optics working fine.
The blue sheet that I found folded into a little wad in the bottom of the fridge when I took the grille off to clean the condenser coils gives guidance for the multimeter tests. I'll go find my multimeter and try those tests.
Help!
Optics continue to test fine.
I wonder if the new module is bad?
Old October 8th, 2008, 01:44 PM
I'm thinking maybe the thermostat is blown.
Now I wonder if I should return the module set and get a new ice maker.
Darnit. This refrigerator is just a bit over a year old.
More issues:
--unplug the fridge
--wait five minutes
Help!
Old October 8th, 2008, 04:51 PM
Don't worry about leaving your door open while you test it, it will turn the ice maker gear without it freezing while you jump the T & H.
Before you do anything else, ohm the in-line thermal fuse, its located on the wiring harness to the ice maker. If that in-line thermal fuse is open, then we found the problem. Because it seems you've done everything correctly.
It comes integrated with the ice maker wire harness, in case you need to order it:
Manufacturer part#2187467 is RepairClinic item#908660
Its the black wire, ohm that black wire for continuity.
indyanne (October 9th, 2008)
Old October 9th, 2008, 08:24 AM
Thanks! I'll let you know how that goes. I can't find my multimeter :-( It's here somewhere. I'm also rehabbing a vintage Airstream trailer, learning a lot about circuits and fuses. This forum works just like the Airstream Forum (airforums.com). Easy to use.
Thanks for getting back so quickly, by the way. I'll try to do the same.
Tags
ice maker, kitchenaid, kscs23inss00
Ice Maker KitchenAid KSRP22FN Side by Side irondan44 KitchenAid 8 October 1st, 2008 07:08 AM
Kitchenaid Ice maker with two problems spp88 KitchenAid 9 July 13th, 2008 01:24 AM
Help with malfunctioning ice maker Grad Sears Kenmore 1 November 25th, 2007 10:49 AM
