Old October 19th, 2008, 07:23 AM
ChipM is on a distinguished road
Default Kitchenaid double oven control panel goes blank
Our Kitchenaid double convection oven model # KEBC208KBL02 elctronic control panel has "gone blank". Oven light still works (indicating power is OK). Oven will "beep" when touch pad keys are pressed, but nothing will turn on. Clock is out.
Have turned off breaker for 15 minutes hopeing it will reset but to no avail.
Help!!
Old October 19th, 2008, 08:11 AM
Looks like you'll need a new electronic clock control board, you have a 5 yr. parts warranty on it:
http://shared.whirlpoolcorp.com/asse...08300886-W.pdf
Contact KitchenAid to have a tech. come out to order it if your oven is under 5 yrs. old.
Its very expensive, here's the one for your model:
Manufacturer's Number: 8302305
8302305
Tags
control panel, double oven, electronic control panel, kitchenaid
kitchenaid oven - preheat and temp display problem BTraut KitchenAid 8 February 7th, 2008 06:16 PM
Blank display on Whirlpool dual oven GBD307 sdelphy Whirlpool 5 December 30th, 2007 10:35 AM
KitchenAid Superba Oven Dim Control Display Arnhemjim KitchenAid 3 June 10th, 2007 07:41 PM
Kitchenaid kebs208dss10 double oven trouble Ann Foust KitchenAid 1 April 5th, 2007 09:20 AM
