We have a KitchenAid side-by-side refrigerator/freezer (model KSRB22FKSS01) that has recently had the freezer defrosting. The problem comes and goes - if we do nothing the freezer will eventually refreeze. If we slide the freezer control to off and then back the compressor will kick back in.
I've spent plenty of time trolling this site for folks with similar problems and it seems that the problem is likely either with the compressor start unit or with the defrost control board. I measured the resistance across the bimetal thermometer when cold and when warm and it appears to be working fine (closed when cold, open when warm). So the question I have is - what do I do next to diagnose which part(s) I need to replace to fix the problem? Thanks! Jon |
Hi Jon,
Its likely your compressor start device relay, this thread here tells how to check it and has the part you can order for your model: [FIXED] How to replace a (Whirlpool/Kenmore Model 106) Refrigerator Start Relay Let us know if thats the problem. Jake
Thanks Jake.
Its not 100% clear to me what part I need to order. It seems that the relay is the single pieces plugged into the side of the compressor. I see both a "start device kit", part number 1177466 and a compressor relay and overload kit, part number 586234. The start kit seems more likely since one or two of the pieces looks like what I think I'm supposed to replace but I don't know what all the other parts are in it. Also - probably outside of the scope of this board, but since the refrigerator is within its "limited warranty" period where parts are covered by not labor, does anyone know if its KitchenAid will pay for replacement parts replaced by a lay person? I'm pretty sure I know the answer, but figured I'd ask the question anyways. Thanks. |
You need this part:
Manufacturer part number 8201799 is RepairClinic item number 1164371 ![]() Unfortunately, only the compressor is covered by the 5 yr. parts & labor warranty. Jake
| Another KitchenAid Warm Fridge Cold Freezer Issue | martindhm | KitchenAid | 4 | August 18th, 2008 10:14 AM |
| KitchenAid Freezer defrosting | rra1251 | KitchenAid | 14 | August 2nd, 2008 10:04 PM |
| KitchenAid KSRS25ILWH01 Refrig warm, Freezer cold | baileyshbr | KitchenAid | 6 | March 19th, 2008 06:04 AM |
| GE Freezer -evap motor fan? | redlady4850 | GE/Hotpoint | 1 | November 10th, 2007 11:41 PM |
| Kenmore Top Freezer Defrosting problems | wenningj | Sears Kenmore | 1 | February 11th, 2007 09:59 AM |
