History:
May/08 Led's associated with operation modes would not illuminate. May/08 Replaced control board 8562996 and dishwasher worked fine July/08 Original problem returns, order second control board and original problem does not go away. Order Overlay that contains the start/cancel/cycle time part number 8573956 and problem solved. July/08 3 successful loads later, thermal fuse blows. I normally run dishwasher in the normal mode with heat dry. The dishwasher does its preliminary stuff then begins counting down at 96. When it gets to 82 (I can duplicate this every time) the dishwasher continues to run and never drops below 82. After 20 to 30 minutes the thermal fuse blows. I have blown the fuse twice watching the process. August/08 Replaced thermister/Optical water sensor part number W10134058. No change in symptoms, counts down to 82 and continues to run (I shorted out the fuse and will only let it run up to 15 minutes). October/08 Replaced heating element part number 8537057. No change. Other info: Incoming water temp is 110 degrees. I ran it through the diagnostics and got the correct results. I disassembled the unit to clean the screen and grinder filter/screen. What is going on at 82 that stops the dishwasher from moving on? Any thoughts would be appreciated. |
Ok, which part on this diagram is the overlay that fixed it July/08:
![]() We have had a few members here that have replaced the ribbon cable and its solved it. Here's the ribbon cable for your model: Manufacturer part number 8531877 is RepairClinic item number 1179803 8531877Jake
The overlay that I replaced is on the Door and Panel part diagram and it is refered to as overlay(white) in my case. There is a ribbon cable that connects it to the part identifed as #5 in the diagram below.
I did order the ribbon cable suggested below and will let you know the outcome. thanks |
Oh Ok, this is a new design I haven't seen yet.
So the overlay(white) is #7 here: ![]() Jake
correct, #7.
Ok, Thanks tro, let us know if the ribbon cable fixes it.
I installed the ribbon cable with no change in performance. Functioning dishwasher as it counts down. At 82 timer no longer decrements, but dish washer continues to run.
The only thing I can add is that there is a slight change in the sound coming from inside the dishwasher a 82. The normal swishing sound plus a different sound, perhaps a humming noise. Sorry, hard to describe. I am trying to figure out what is going on at 82 so I am listening closely. Is there something that I can disconnect and run it through the cycle? |
Well, this is very odd, you've changed basically everything that has to do with this issue, not sure whats causing it now. You can return that ribbon cable for a full refund. The packaging slip that came with it explains how. You may have a deeper underlying problem that a KitchenAid factory tech. will need to come out to your house. Jake
Thanks for trying. I will let you know shat the outcome is.
Ok, sounds good.
| double oven blows thermal fuse | janrog300 | Whirlpool | 12 | September 29th, 2007 10:25 PM |
| Kenmore Dryer blowing Thermal fuse | boondoggle | Sears Kenmore | 1 | September 27th, 2007 10:20 AM |
| thermal fuse keeps blowing | chanchamone | KitchenAid | 2 | July 9th, 2007 08:55 AM |
| Kenmore 70 Series - Thermal Fuse Keeps Blowing Out | rebepany | Sears Kenmore | 5 | March 16th, 2006 05:56 PM |
| Kenmore keeps blowing thermal fuse. HELP! | tjs | Sears Kenmore | 7 | December 20th, 2005 04:16 AM |
