Old November 11th, 2008, 10:02 AM
dewcool is on a distinguished road
Default temp control?
Hi Guys, I'm working on a side by side, md# ksrs27fgss11. The control unit to the fridge is open, ( I thought i felt air flow), but still fridge side is still warm. I think i hear the fan running, but not sure, and i test the thermostat, seems ok. I suspect a main board, what you think? Thanks for all your help, DEW
Old November 11th, 2008, 03:44 PM
Hi Dew,
I would first take the food out of the freezer, then take the shelves out, then take off the back panel inside the freezer and check your evaporator coils, they should all have a thin layer of frost on them. Not caked up with frost.
Then while your in there you can see if the evaporator fan is running.
Also take the temp. of the freezer.
Report back what you find.
Old November 12th, 2008, 07:35 AM
O.K. Jake, I took everything out in freezer, and all was fine, fan running, and defrost working just fine. I looked into the air diffuser again and saw it had closed. Temp in freezer was perfect, but reading in fridge was at 50 degrees. im ordering the diffuser, but is there a main board on the md.?
Old November 12th, 2008, 08:21 AM
Yes, its likely the diffuser.
Here's the diffuser for your model:
Manufacturer's Number: 2209751
icon
icon
icon2209751
No, on this model you DON'T have a main control board.
Whirlpool Range Temp Control Bill Gray III Whirlpool 1 April 11th, 2008 06:42 AM
Whirlpool/Kirkland SAWS800JQ0 Temp Control emoriart Whirlpool/KitchenAid 1 July 20th, 2007 11:00 AM
Frigidaire FRS6LF7FQ3 Freezer temp control broke? holzert Frigidaire/Electrolux 7 June 19th, 2007 10:47 PM
362.75471691 Gas Range temp control problem Frank J. Sears Kenmore 1 July 6th, 2006 08:47 AM
Whirlpool burner temp control ncphoto Whirlpool 1 March 30th, 2006 11:47 PM
