Results 1 to 7 of 7
Thread: Kitchenaid KUDS01FLSS3 Thermistor - Wrong Size
    viadesigntech is offline Premium Member
    Nov 2008
    Pennsylvania
    Default Kitchenaid KUDS01FLSS3 Thermistor - Wrong Size
    First time using this - seems like a good resource. Motor was growling and not cleaning so I thought the motor was about to go after 4 years. So...... I replaced the pump/motor assembly. Everything looked fine until it came to the thermistor. The old and new pump assembly are identical as far as I can see with the exception that the old thermistor is too small for the socket on the bottom of the new pump assembly. The old pump has asmall socket hole as in this photo:
    Old pump to be replaced: http://www.repairclinic.com/referral...1265&N=1060514
    The new pump has larger thermister socket like in this photo http://www.repairclinic.com/referral...1265&N=1173212
    Do I have the right pump for a KUDS01FLSS3? Part# 1173212?
    Can I use this new pump? What is the correct thermistor to order for this pump?
    Any help would be appreciated as the entire thing is in pieces in the kitchen now for two days and wife is getting steamed.
    I double checked what pump/motor assembly yours uses, and its definitely this one:
    http://www.repairclinic.com/referral.asp?R=1265&N=1060514
    Manufacturer part number 8535150 is RepairClinic item number 1060514
    What part numbers are on the box that it came in?
    They may have sent the wrong one by accident. As far as I know you can't intermix thermistors.
    The part# on the box should say 8535150.
    Paul S is offline Premium Member
    Dec 2009
    Michigan
    The same thing happened to me. Was this question answered?
    Hi Paul,
    Is yours the exact same model?
    Dec 2009
    Michigan
    Yes -- wrong box, they swapped for correct one. But when re-assembling, I seem to have an extra drip shield. One is attached to the motor -- where does the second attach?
    Dec 2009
    Michigan
    Never mind -- it's the drip shield for the drain motor.
    Ok Paul.
  1. Replies: 8
    Last Post: February 7th, 2008, 07:16 PM
  2. KitchenAid Executives: do not stand behind products
    By Circagirl in forum Whirlpool Reviews
    Last Post: October 5th, 2007, 11:13 AM
  3. Replies: 2
    Last Post: November 11th, 2006, 11:09 PM
  4. Replies: 1
    Last Post: September 14th, 2006, 11:53 PM
  5. Kitchenaid vs Whirlpool?
    By rv8 in forum KitchenAid
    Last Post: January 26th, 2006, 12:22 AM
