Results 1 to 6 of 6
Thread: Kitchenaid Superba KUDA2207WH4 just weak
    k6jek is offline Member
    Sep 2005
    Sunnyvale CA
    Default Kitchenaid Superba KUDA2207WH4 just weak
    My 13 yr old SuperBa KUDA220TWH4 now does a crummy job. I notice the lower arm does not move. Where ever it was at the start of the cycle, there it is at the end. It seems to have a lot of friction.
    My guess is that either the pump has somehow gotten weak (do they do that) or the plastic has gotten so rough the arm is just too tough to move.
    Dishwasher appears to be filling just fine.
    I'm happy to take some guesses, replace a few things, and guess some more. What should be my first guess?
    Jon
    I would start first with taking off the lower spray arm to check for gunk in the bearing were it turns. If not, then you may have to start taking the upper pump assembly off to check for gunk there as well, or a broken impeller.
    Sep 2005
    Sunnyvale CA
    Quote Originally Posted by Jake
    Thanks. I'll start there.
    Ok, Sounds good k6jek,
    Good Luck,
    Sep 2005
    Sunnyvale CA
    Default Now fixed.
    I removed the wash arm and discovered two things: the metal washer that sits between it and the wash arm support was just plain missing; the fine mesh screen on the wash arm support was completely plugged with hard water deposits. I bought a new wash arm support from RepairClinic.com. It came with a new washer. This fixed it. The ancient KitchenAid lives another day.
    Thanks for the help,
    Jon, K6JEK
    Awesome Jon, Glad to hear you found the problem and fixed it!
    Thanks for the update,
  1. Kitchenaid Superba KSSS42MW - Repair or replace?
    By udahman in forum KitchenAid
    Last Post: November 30th, 2012, 10:49 AM
  2. Ice Maker Issues - KitchenAid Superba KSCS25I
    By rhayward in forum KitchenAid
    Last Post: August 31st, 2011, 01:29 PM
  3. KitchenAid Superba Oven Dim Control Display
    By Arnhemjim in forum KitchenAid
    Last Post: June 10th, 2007, 08:41 PM
  4. Replies: 2
    Last Post: November 11th, 2006, 11:09 PM
  5. Kitchenaid Superba Range - Error code Sab
    By Shrk2th in forum KitchenAid
    Last Post: September 22nd, 2005, 04:52 AM
