Old December 30th, 2008, 07:32 AM
vermonter is on a distinguished road
Default Kitchenaid weird icemaker problem
Icemaker enthusiasts;
First, thanks for the site..joined w/premium membership; this has been a great site for me!
Anyway the icemaker on my Kitchenaid KS2G25FKWH05 does not work...no ice. Here's what we know:
1. Can jumper the icemaker to rotate the blades using the normal procedure (interestingly I have to manually push the door switch hard to make it...but thats another problem!)
2. The optical IR boards etc work fine..again you can get the icemaker to run w/normal jumper procedure
3. No water out...I measured voltage across the water valve IM side..no power. Tried switching the IM and cold water power; the cold water solenoid power does work....valve did not work....failed?
** Note: there is water in the IM water line; I pulled and can drain it..no blocks.
** Note2: HOWEVER there is no power to the IM solenoid when I jumper and rotate the icemaker. I DO get power at the IM testpoints N and V but NO POWER at the white and tan wires at the solenoid....
Question...while this seems to indicate the water valve is bad not getting power to it also seems to be another failure....perhaps in the "Electronic Defrost Control and Water Filter Indicator" Board? I notice from wiring diagrams that the tan wire from the IM goes to that board.
Thanks again; yep its strange....much oblidged and happy holidays!
Old December 30th, 2008, 08:00 AM
Please double check your model# again, that one doesn't seem to pull up.
Did you ohm your black thermal fuse for continuity, thats integrated in your wiring harness to your ice maker?
Old December 31st, 2008, 05:12 AM
Default Further info
Jake; Thanks for the reply. The model number is KSRG25FKWH05; I ohmed out the black wire containing the "fuse" and it is good....which is confirmed from when I test the IM and the mold gets hot.
Thanks, Ed
Old December 31st, 2008, 08:26 AM
Thanks Ed,
Now when you tested for 120 volts at your ice maker solenoid on your water inlet valve in the back of your refrigerator, did you jump L & V test points on the ice maker module with a jumper wire while you used your volt meter to test for 120 volts at your ice maker solenoid on your water inlet valve?
Old December 31st, 2008, 12:56 PM
Jake; Yes. I jumpered the IM to make it cycle and measured the voltage across the IM testpoints N and V; I did it again and measured at the solenoid but got zero volts...thats why its weird and makes me wonder about the electronuc defrost control board....
Thanks, Ed
PS Happy New Year!
Old December 31st, 2008, 04:41 PM
No Ed, I asked if you installed a jumper wire in L & V then tested for 120 volts at your solenoid. Not N & V.
L & V is what sends 120 volts to the solenoid to make the water come out.
Happy New Year!
Old January 2nd, 2009, 04:38 AM
Default Did both
Jake; I did both; I confirmed 120V at the testpoints and then confirmed zero volts at the solenoid. Thanks, Ed
Old January 2nd, 2009, 07:16 AM
OK..new data. I finally understood what you wanted..jumpering something not in the manual. Interesting; jumpering L and V as you direct supplied ~ 40 VAC to the solenoid. I tried this twice; I also measured the voltage at testpoints N and V while jumpering L and V as well as the solenoid 2X..again 40 VAC.
However I then ran the usual cycle initiated by jumpering T and H (and closing the door and making the light beam I did get 120VAC at both testpoints N and V on the icemaker as well as 120VAC at the solenoid.
I'm not sure why the test you described did not supply 120VAC but where I am the water valve is bad.
Thanks.
Old January 2nd, 2009, 08:47 AM
Well whats interesting is that you only got 40 volts at the water valve solenoid, you should of got 120 volts there. So I'm not sure replacing the water valve will fix it. I'm leaning more towards the module or the complete ice maker assembly.
Here's the ice maker module kit for your model:
Manufacturer's Number: 8201515
Complete icemaker assembly
But it would be a good idea to order the water valve just in case:
Manufacturer's Number: 4389177
You can always send back the part you don't need within 30 days for a full refund.
Old January 4th, 2009, 01:06 PM
Jake; Thanks...I ordered the water valve; we'll see how that goes.
One question; the part shown has an additional water line attachment mine does not have...the single "feed" portion thats attached to the bracket (and has its own bracket)..whats that? Thanks, Ed
[FIXED] Amana - Icemaker or inlet valve problem ozarkmud Amana 5 January 12th, 2009 04:21 PM
Icemaker Problem on GE Profile Refrigerator caf@e-navtech.com GE/Hotpoint 1 June 27th, 2007 07:13 PM
Another Whirlpool Icemaker Problem BCB Whirlpool 5 June 21st, 2006 08:11 AM
Kitchenaid Icemaker won't harvest icecat14 KitchenAid 1 February 7th, 2006 08:35 PM
Kitchenaid Free Standing Icemaker KUISI5NRHB6 rsirmans KitchenAid 3 December 10th, 2005 09:14 AM
