Old February 22nd, 2009, 10:29 AM
mleeper is on a distinguished road
Default KUDP01FLWH1 won't stop running
Unit is about 5 years old and has worked great up until last week. It will start running as normal on any cycle but it will not every stop. It will seem to finish and then start up again. It will drain and appears to be heating but without manual intervention it will run for hours.
Any ideas before we call a repair guy?
Old February 22nd, 2009, 09:30 PM
So does it run the normal cycle for about 60-80 minutes, then start all over again by itself? Or does it runs for many hours without stopping at all?
Its likely a bad control board, if it just runs the normal 60-80 minutes, then starts all over again.
Part#8564542(click photo for pricing/ordering information)
If its runs for hours in the same wash cycle without it draining and such then its likely a bad thermostat under your tub.
This is from Rick(redbeardnmt):
There is a small thermostat, about the size of a dime, held to the bottom of the tub with a metal bracket. You'll see it, it has two wires on it. Here's how to check it. Take the two wires off and jump them together. See if it goes through the cycle. If it does then replace the thermostat part# 661566.
Help with msd2756dew stop running...hic.. punks123 Maytag/Magic Chef/Admiral/Jenn-Air 25 September 25th, 2007 04:44 PM
GE Spacemaker JVM1630WB stop pressed still running riverfour GE/Hotpoint 0 August 6th, 2007 09:25 PM
Maytag Fridge WONT STOP RUNNING sheepdog Maytag/Magic Chef/Admiral/Jenn-Air 1 June 22nd, 2007 02:27 PM
How can I stop this fridge from running!!!??? brad123 Maytag/Magic Chef/Admiral/Jenn-Air 6 August 29th, 2006 01:17 PM
Kenmore Electric Dryer Won't Stop Running WadeB Sears Kenmore 2 December 7th, 2005 06:46 PM
