  #11
Old May 18th, 2009, 08:03 PM
Never mind, I see your serial# in your first post, so it looks like a 2005 model?
I've posted both links that come the closest to your model#, It should be similar to yours, if not, I'm afraid I can find the exact link to yours.
In cases like this where I don't have a repair manual either, I just have to start removing the door frame screws, then the door frame comes off, then you will see more screws inside that will need to come out, just make down on paper where you took them out from as well as the inner door parts.
You need to remove the door from the oven first, read page 22 here it tells you how:
http://shared.whirlpoolcorp.com/asse...%208300886.pdf
Kitchen Aid Oven light problem mark1505 KitchenAid 3 January 26th, 2009 08:14 AM
Broken Maytag Oven Glass Door cdewing Maytag/Magic Chef/Admiral/Jenn-Air 5 January 19th, 2009 09:25 AM
Inside door glass on Kitchen Aid Range superpop KitchenAid 1 January 11th, 2009 09:30 AM
Kitchen Aid Double Oven KGBS276XWH0 sexey81 KitchenAid 5 December 6th, 2007 06:06 PM
kitchen aid oven failure code F1E1 larman53 KitchenAid 1 October 31st, 2007 04:22 PM
