Old April 15th, 2009, 12:42 PM
Tee Dubbya is on a distinguished road
Default KUDS01IJBL0 - Upper Rack Not Cleaning and ...
My problems began with the gradual collection of residue (detergent?) on the upper rack sliders. Lately the unit has not been washing & rinsing the upper rack very well. I did a lot of reading on the forum here (great resource btw) and disassembled the unit all the way down to the chopper using the Whirlpool manual frequently referenced. I did find a lot of deposits, some rather large, and cleaned everything out before re-assembling.
I made sure the drain was free of obstruction and verified it was emptying the unit completely. And getting the chopper back in there was a real pain.
No improvement. Dishes still have food residue on top rack.
Another problem I discovered is the unit is filling up until the overflow switch is triggered. I discovered this by letting the unit fill and then pressing on the overflow float before the cycle begins. I can hear the switch disengage. At first I lifted the float only to find it was already out of travel.
My local appliance guy and I are stumped because the unit continues to operate even though the switch is tripped. He says that should never happen and I should seek Professional help.
We seem to think the upper arms are not getting enough pressure, but are not sure where to tackle the source of the problem(s).
I'm pretty confident I will get the answer here.
Old April 15th, 2009, 01:40 PM
Its likely the wash motor impeller assembly, KitchenAid/Whirlpool had some issues with wash motor impeller assembly wearing out prematurely, and causing the loss of wash power through the upper/lower spray arms.
You can either order just the wash motor(more work to install), or the complete sump/wash motor assembly(easiest to install).
But the repair manual you have will show/tell you how to install both either way.
Here's the cheapest price I found on your wash motor assembly:
8534942
Here's the sump/wash motor assembly for your model:
Manufacturer's Number: 8535150
8535150
Old April 15th, 2009, 01:55 PM
Thanks for the prompt reply on the water pressure issue.
Any ideas on why the unit is "overfilling" (or is it)? Does the fill operation use a timed or mechanical dependency (float switch)? My understanding was it should be timed and the overflow float is there as a stopgap measure. But if the float is the device used to switch off the fill (like a toilet) then I am mistaken.
Old April 15th, 2009, 02:19 PM
It depends on the water pressure, if you have above average water pressure then it may fill faster, thus making the float stop the water before the timed fill stops it.
As long as its not overflowing onto the floor then its fine.
GU1500XTLS1 dirty dishes on upper rack and residue on all dishes klehman Whirlpool 5 December 18th, 2008 09:15 AM
Grit left on items in upper rack amtravco KitchenAid 3 January 3rd, 2008 10:03 AM
Removing upper rack - GE dishwasher Freddw6 GE/Hotpoint 5 September 27th, 2007 11:35 PM
Kenmore 665.17342300 Not cleaning top rack Clark Griswold Sears Kenmore 3 July 30th, 2007 10:56 PM
Noisy upon start, Not cleaning Top rack coach_dorsey Sears Kenmore 3 June 11th, 2007 08:59 AM
