Results 1 to 8 of 8
Thread: KitchenAid Gas Range KGSK901SSS00 Oven will not ignite
    rock334 is offline Premium Member
    Apr 2009
    Millbrook, Alabama
    Default KitchenAid Gas Range KGSK901SSS00 Oven will not ignite
    We have a problem with a KitchenAid Gas Range oven failing to ignite (Model: KGSK901SSS00) We have replaced the Safety Check Valve, Spark Igniter, and Direct Spark Ignition Control Board. The oven is getting gas and you can hear the igniter click for a few seconds then it shuts off. Also, while installing the DSI Control Board, we noticed 2 thermal fuses behind the control panel. We did a continuity test on both of them and found one of them to be bad. We ordered a new thermal fuse. When we recieved the new fuse, we performed a continuity check on it before installing it and it failed to show continuity also. Is that normal or did we get a bad fuse? Can the thermal fuse prevent the oven fron igniting? If not, any suggestions will be appreciated.
    Hi rock,
    No, its very rare for it to be a thermal fuse issue.
    Did you go through the flow chart of the DSI repair manual here on page 24:
    http://www.applianceblog.com/manuals/DSI_manual.pdf
    Apr 2009
    Millbrook, Alabama
    Wow, thanks for the manual. I've never seen this. I'm sure we'll be able to figure the problem out with this. If not, I'll definately let you know. Once again, thanks!
    Billy
    Oh yeah, pertaining to the fuse: should the new fuse have shown continuity or is this a different type fuse?
    Thanks, once again...
    It may be a diferent fuse, whats the part# of that fuse?
    Apr 2009
    Millbrook, Alabama
    The fuse part number is 9757807
    Yes, thats #23 here:
    Part#9757807
    It should have continuity. If you got it new and it doesn't have continuity, then its defective, you would need to exchange it for a another new one.
    Also check #37 for continuity as well.
    Make sure the power to your range is off first before checking for continuity.
    Here's #37 for your model:
    Manufacturer part number 9759242 is RepairClinic item number 1061375
    Apr 2009
    Millbrook, Alabama
    Thanks for the reply. I'm taking the fuse back now. You have been a great help!
    Ok, sounds good rock.
  9. The Following 2 Users Say Thank You to Jake For This Useful Post:
    rock334 (April 29th, 2009)
  1. Kenmore gas range - oven burners won't light
    By squirkie in forum Sears Kenmore
    Last Post: January 19th, 2012, 05:45 PM
  2. Kitchenaid Superba gas oven stopped working
    By PeaJay in forum KitchenAid
    Last Post: November 21st, 2011, 09:54 AM
  3. Gas vs. Electric Range? Here is one more view...
    By bobl in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 9th, 2008, 04:00 PM
  4. ES400 Gas Range oven light
    By LBest in forum Sears Kenmore
    Last Post: November 22nd, 2007, 03:48 PM
  5. Kitchenaid KGRT507 gas range slow to heat
    By Bobbie Hall in forum KitchenAid
    Last Post: March 16th, 2007, 07:30 PM
