Old July 19th, 2009, 04:54 PM
cjkl50 is on a distinguished road
Default KitchenAid KudP02CRBL1 D.O.A
I started having problems first with the soap door not opening. I replaced the soap assy, and still nothing. I then replaced the control board and it opened once and not after that. Im waiting on a new contol board to come under warranty and now this morning it is DOA. I tried turning the power off and back on and it did not work. Do i need to replace the thermal fuse now? This dishwasher has been worked on now seven times since I have owned it. I will never buy another Wirlpool product again even if you gave it to me for free!!!!!!!!!!!!!!!!!!!!!
Old July 19th, 2009, 09:37 PM
I use my volt meter to test for 120 volts at the thermal fuse first, if you get 120 volts, then turn the power off to your dishwasher and ohm test the thermal fuse.
Here's the thermal fuse for your model:
Manufacturer part number 661663 is RepairClinic item number 1176509
661663
Your thermal fuse is #6 here:
http://content.searspartsdirect.com/lis_png/PLDM/K0611027-00002.png
Just remove the 6 #8 screws on the inside of your control panel, then you can access it.
I use an ohm meter to test continuity on the thermal fuse. If no continuity, then its bad.
You can get a cheap volt/ohm meter at Radio Shack if you don't have one.
cjkl50 (July 20th, 2009)
Old July 20th, 2009, 03:10 PM
Thanks Jake! Is it located in the door near the control board that I have replaced??
Old July 20th, 2009, 04:25 PM
Yes it is.
Big Problems with New KitchenAid Dishwasher FredTomball KitchenAid 1 November 24th, 2007 01:01 PM
KitchenAid Executives: do not stand behind products Circagirl Whirlpool Brands Forum 1 October 5th, 2007 10:13 AM
Kitchenaid Diswasher Replacement, & Parts Question, Please Robert11 KitchenAid 1 September 14th, 2006 10:53 PM
Kitchenaid vs Whirlpool? rv8 KitchenAid 1 January 25th, 2006 11:22 PM
Kitchenaid Free Standing Icemaker KUISI5NRHB6 rsirmans KitchenAid 3 December 10th, 2005 09:14 AM
