I have a KitchenAid dish washer model KUDS01FLWH6. the door keeps popping open and stopping the cycle. if I put something in front to hold it shut it wrks fine.
Ok, by chance did you install a new door gasket then this started happening? Reason I mention this is this happened to me after I installed a new door gasket, and I had accidentally installed it backward causing the door to pop open.
If this isn't the case then the cause would be your door latch is worn out. Here's the cheapest one I found for your model: Manufacturer's Number: 8193830 Jake
no I havent installed a new gasket. how long do latches last?
No set time, how often do you use the dishwasher? Daily? Many times a day?
If you have a large family or many family members/relatives living in the same household, then parts wear quicker. Jake
I had the same problem after replacing the door seal (which applied more pressure on the closed door). I used a 2x4 wedged against the handle to keep the door closed until a new latch arrived. The new latch worked for about a week before I started to have the same problem again. The redesigned strike plate is probably the answer (now that I know about it), but I fixed my problem by LIGHTLY sanding a small flat on the back edge of the strike with a Dremel tool. That allows the plastic latch to grab the strike and stay latched on - as opposed to rolling off a rounded edge. I would be cautious about making the flat too large or jagged since it may make the door hard to open or cause damage to the latch over time.
LinkBack to this Thread: http://www.applianceblog.com/mainforums/kitchenaid/16304-door-keeps-popping-open.html
| KitchenAid on Appliance Blog Forums | BoardReader | This thread | Refback | August 25th, 2009 06:13 AM | |
| amana lg9209w2 door open message | neaderhiser | Amana | 12 | November 12th, 2009 01:59 PM |
| Kenmore 721.68280790 light, fan & turntable run with door open | GeneMc | Sears Kenmore | 2 | July 31st, 2007 04:17 PM |
| Kenmore Elite: freezer OK, food section too warm, air-damper is open. | t2d | Sears Kenmore | 10 | June 23rd, 2007 07:41 AM |
| Samsung RS2630WW Water Dispensor sticking open | TonyL | Refrigerators & Freezers | 4 | February 27th, 2007 11:19 PM |
| Detergent Door will not open! Need wiring diagram. | Bob Swerski | GE/Hotpoint | 11 | July 10th, 2006 10:12 PM |
