Old August 31st, 2009, 11:08 AM
adrian is on a distinguished road
Default KitchenAid dishwasher-long cycles.
I have a KitchenAid dishwasher (model KUDI01ILBL1, 5 year old). and the wash cycle takes almost 4 hours to complete. I suspect the control panel. Am I thinking correctly?
Adrian
Old August 31st, 2009, 01:54 PM
Hi Adrian,
Its possibly the thermostat under the front of your tub, this thread explains what to do:
Quite Partner IV 8533704 Whirlpool Gold
Yours uses the exact same thermostat, in case you need to order it.
Old September 4th, 2009, 09:49 AM
Default Element not heating
Hello Jake,
I had a control panel and a thermostat. I installed the thermostat and no help. I felt the coil and it was ice cold. Am I to assume the bad coil is causing the long cycles for the very reason it is not heating? I tried to find a part number for the coil but no luck.
Adrian
Old September 4th, 2009, 09:50 AM
Default Bad terminology
I should have said heating element instead of coil.
Adrian
Old September 4th, 2009, 02:28 PM
On your model, it comes with the upgraded control board, you can order it here:
Manufacturer's Number: 8194200
8194200
Its mandatory to change the control board when you change the element.
The easiest way to change the element:
You unhook your plumbing, electrical, and drain hose from it and pull your dishwasher out to get to the back of it, thats where the plastic nuts hold it in place, they just unscrew to remove it, remove the wires that connect to each heater terminal first.
LinkBack to this Thread: http://www.applianceblog.com/mainforums/kitchenaid/16453-kitchenaid-dishwasher-long-cycles.html
Posted By For Type Date
KitchenAid on Appliance Blog Forums | BoardReader This thread Refback September 12th, 2009 05:34 AM
[FIXED] Kenmore dishwasher model #665.15899100 has long cycle time isamuelson Sears Kenmore 32 February 25th, 2008 12:32 PM
Big Problems with New KitchenAid Dishwasher FredTomball KitchenAid 1 November 24th, 2007 01:01 PM
KUDPO2CRBL4 Kitchenaid Dishwasher Door won't open ucsbgrad86 KitchenAid 4 June 1st, 2007 01:14 PM
Dishwasher Leak After End of Cycles KitchenAid KUDS220T0B0 dgodesky KitchenAid 6 March 20th, 2007 11:09 PM
KitchenAid (Whirlpool) DISHWASHER Runs to Infinity - how test TStat? pgtr Washers 2 December 5th, 2006 10:09 PM
