Results 1 to 10 of 14
Thread: Kitchenaid KSCS25INWH01 not defrosting
    johnnyspeed is offline Premium Member
    Aug 2009
    howell
    Default Kitchenaid KSCS25INWH01 not defrosting
    Hi, I have a Kitchenaid that has a issue the mod. Is KSCS25INWH01 ser. #ST4432763 the service and wiring sheet is # 2223419v this all started after the refer. Door got left open a little bit over night, I think it is coincidental. The evaporator coil will frost up on the fins and ice up on the sides really bad in about 3 to 4 days after I remove the back cover and de-thaw it with a hair dryer. I have had to do this 3 times now, the freezer set @ 6 degrees and the refrigerator set @ 35 degrees, I have checked the air damper and it is not froze up and is open. The one funny thing that I have notice is the drain in the bottom will freeze closed, I can pour water through it once the little ice plug melts when I am defrosting it. I ran it through the diagnostic check after it was at normal operating temp and everything was ok till I got to step #7 it said the bi-metal was open, the chart said to bypass it, how do I do that? Any help would be greatly appreciated.
    Thanks JD
    To bypass the bi-metal, you would disconnect the wires from it and join them together with electrical tape, or if you don't have quick disconnects on it, you would cut the wires away from the bi-metal and use a wire nut to spice them together.
    Aug 2009
    howell
    I was a little hesitant about cutting the wires so I figured a better start asking some questions. So now when I do the diagnostic check with the bi-metal by passed the heater elements should come on rite? And the read out should indicate the switch is closed now rite? How hot or warm do the elements get? If that all checks out good am I to assume that the bi-metal is bad?
    Thanks JD
    Correct.
    Correct.
    It will get pretty hot, don't touch it, it will burn your fingers.
    Yes.
    Here's the defrost Bi-Metal for your model:
    Manufacturer part#2321799 is RepairClinic item#1399517
    Aug 2009
    howell
    Ok, I by passed the by-metal and the heater did come on but the read out still said the the switch was open. dose that mean the board is bad?
    Thanks JD
    Possibly, can you take off the by-pass and let it get cold again then check it in a couple hours?
    After the bi-metal gets cold again, you can also ohm the bi-metal for continuity.
    Aug 2009
    howell
    I will try that, I am leaveving for the weekend rite now so it will half to be monday.
    thanks for am the help and enjoy your labor day.
    JD
    Ok JD, sounds good.
    Happy Labor Day Weekend.
    Aug 2009
    howell
    Ok, after a great weekend I wake up this morning @6am to nice warm fridge and cold freezer. The bi-metal is good and cold, so I tested it for continuity and it had none.
    So is the switch is bad and the diagnostic checker is lieing to me?
    Ok, then that means your bi-metal is the problem. Order it and change it.
  11. The Following User Says Thank You to Jake For This Useful Post:
    johnnyspeed (September 9th, 2009)
  1. September 5th, 2009, 04:29 PM
  1. KitchenAid Freezer defrosting
    By rra1251 in forum KitchenAid
    Last Post: February 18th, 2012, 11:23 AM
  2. Kitchenaid Freezer defrosting - diagnosis help
    By arrniej in forum KitchenAid
    Last Post: October 26th, 2008, 07:32 PM
  3. KitchenAid Executives: do not stand behind products
    By Circagirl in forum Whirlpool Reviews
    Last Post: October 5th, 2007, 10:13 AM
  4. Replies: 1
    Last Post: September 14th, 2006, 10:53 PM
  5. Kitchenaid vs Whirlpool?
    By rv8 in forum KitchenAid
    Last Post: January 25th, 2006, 11:22 PM
