Old September 30th, 2009, 03:28 PM
trschneider is on a distinguished road
Default KUDS01DJ Wont Start
I replaced the door handle and handle springs on my dishwasher and when I started the dishwasher it cycled for 2 minutes and then humms. Reopened
the panel and checked all the leads and everything seems to be in place.
I kept the door open while pushing on the door switch and it did the same
things so it doesnt appear to be the lock or door switch. Like a boob...i
didnt cut the power to the unit while I repaired it...I tried turning the power
to the unit off for a few minutes to see if it would reset. I dont think there
is anything wrong with the motor/chopper/impeller because it was working
fine with the broken handle. Is there a reset cycle I need to do?
Old September 30th, 2009, 07:52 PM
Did it fill with water at all? Put your hand on the water inlet valve while its humming to see if thats whats humming.
Did you turn your water supply off to your dishwasher?
Old October 1st, 2009, 02:55 PM
The water fills and I can also have it jettisoned by pushing the lower button on the control panel when the humming starts. The humming appears to come from the motor/lower spray arm...ugh. I will try to check that for jams. Any advise would be appreciated...Thanks
Old October 1st, 2009, 04:14 PM
I took the spray arm off, the cover, and the screen to the chopper. Pulled out a long chicken bone and put it all back together and it still humms...Going to try to take the chopper cover off and see if that is jammed....Any suggestions?
Old October 1st, 2009, 04:59 PM
Took the chopper cover off and it appears to be fine. Chopper seems to be ok. Nothing jammed in it. Now what?
Old October 1st, 2009, 06:43 PM
You may have more chicken bone lodged further down in the motor impeller, you'll likely need to pull the motor/impeller assembly out and check it.
LinkBack to this Thread: http://www.applianceblog.com/mainforums/kitchenaid/16680-kuds01dj-wont-start.html
Posted By For Type Date
KitchenAid on Appliance Blog Forums | BoardReader This thread Refback October 2nd, 2009 06:14 AM
[FIXED] How to replace a (Whirlpool/Kenmore Model 106) Refrigerator Start Relay Jake Refrigerators & Freezers 93 January 19th, 2010 11:20 PM
Kemore Dryer - will not start Mr. Big 173rd ABN Sears Kenmore 1 May 14th, 2009 10:23 AM
Frigidaire Dryer won't start without a "push" web Frigidaire/Electrolux 0 October 15th, 2007 06:30 AM
Help Maytag Dryer MDE9206AYW No Start rvpeddler Maytag/Magic Chef/Admiral/Jenn-Air 9 July 23rd, 2007 01:42 PM
Kenmore series 70 wont start cefox01 Sears Kenmore 3 April 16th, 2006 02:53 PM
