Old October 19th, 2009, 07:19 AM
jafer is on a distinguished road
Default Kitchenaide Kuds01FLSS1
My dishwasher model #kuds01FLSS1 is leaking from the bottom when it is running. Please help with fix suggestions.
James
Old October 19th, 2009, 08:06 AM
Hi James,
Is it a slow leak/drip? or gushing out?
Open the door when you see it leaking and see if its really sudsy inside.
Old October 19th, 2009, 11:10 AM
It did not start dripping until an hour into the dishwashing cycle.
I can see the small dripping leak coming from the bottom/right of the dishwasher. I attached a picture of where it's dripping from (picture.jpg)
When I openned the dishwasher during the leak, it was not sudsy.
James
Old October 19th, 2009, 03:24 PM
Ok James,
Looks like its leaking either from the float assembly or the inner door where your detergent dispenser is located.
You may need to remove the outer door panel to get a better view. Do you know how to remove it?
Here's the float assembly for your model:
Manufacturer's Number: 8193506
icon
icon
icon8193506
Old October 19th, 2009, 03:29 PM
Unfortunately, I do not know how to remove the door panel. Is it very difficult and not recommended for me to do? Do you have link to show how to remove?
Is that float assembly easy to put in?
James
Old October 19th, 2009, 03:37 PM
Yes, the float assembly is easy to install.
Here's the instructions to remove the outer door panel:
Read Page#17 here:
Where it says:
1. Remove the eight (8) screws securing the outer door panel to the dishwasher door frame.
(Fig. 3-7)
Remove the outer door panel from the door frame.
Old October 19th, 2009, 07:28 PM
I took out the front of the door. I did not see water coming from the inner door where the detegent dispenser is coming from. Water is definately coming down the float assembly. Should I replace the whole float assembly? or should I try to tighten. Does the float assembly usually go bad after 5 or so years?
James
Old October 19th, 2009, 07:58 PM
Yes James, I'd change the float assembly.
It can go bad after 5 years or so.
Kitchenaid KUDS01FLSS1 Not Starting Island Dog KitchenAid 9 January 8th, 2010 09:32 AM
KitchenAide KSRS25IHWH Ice Dispenser now working mdmerlin KitchenAid 1 March 24th, 2009 12:33 AM
Kitchenaide Issues with Temp Probe TheRASGuy KitchenAid 10 March 21st, 2008 10:48 AM
KitchenAide Dishwasher randomly spills water emcalear KitchenAid 1 January 3rd, 2006 05:48 PM
KitchenAid KUDS01FLSS1 will not drain randyy KitchenAid 5 October 10th, 2005 09:07 PM
