I have a Kichen Aid KUDS24SEBL4 dishwasher. It is dead and does not run or have any lights on the panel. I had this same problem last year and they replaced the thermal fuse.
There is water in the bottom of the tank also that does not drain, due to power shut down. How do I drain this machine. I think I can change the fuse, found several threads to this issue already. |
Its likely your thermal fuse is bad. You can ohm it for continuity with an ohm meter to see if it has no continuity. Thats what I always do. ![]() Do you know if the tech. installed the new wires that came with it? If they didn't then thats the reason its blown again. Part#675796 Fuse assembly with wire harness ![]() The wires must be replaced with it that it comes with. ![]() Jake
Clay Mangum (November 2nd, 2009) | ||
Jake:
I do not know if he replaced the wire. He replaced the fuse and it operated for one day and then blew again. He replaced the fuse the second time and it has worked for about a year. I have ordered the repair manual for the unit. How do I drain the sitting water in the bottom? |
You can use a WET/DRY VAC or wait till the new fuse to come.
| Kitchen aid supra side-by-side freezing problem | Honeysucklerose | KitchenAid | 1 | July 8th, 2009 10:54 PM |
| Kitchen Aid oven with broken glass | frennings | KitchenAid | 10 | May 18th, 2009 08:03 PM |
| kitchen Aid Ice maker stopped making ice | SAWDUST7 | KitchenAid | 5 | July 20th, 2008 07:19 PM |
| Freezer temp changes on Kitchen Aid Superba | Pete V | KitchenAid | 3 | April 8th, 2007 10:34 PM |
| Kitchen Aid | carwasher44 | Buy, Sell or Trade | 0 | December 29th, 2006 11:23 PM |
