Old November 7th, 2009, 04:49 AM
markaw1 is on a distinguished road
Default Bad flapper valve or motor problem (or both!)
I have a Kitchenaid KUDP01FLSS6.
Dishes are a bit dirty after a cycle, and often there is detergent left in the reservoir, though the detergent door is always open at the end of the cycle.
The fitrst thing I checked is the flapper valve / chopper assembly described in detail in this post - [FIXED] Kenmore Dishwasher goes to next cycle before water full
The chopper is fine, and the rubber check valve seems fine, though very flimsy. After researching this blog and every resource I could find - how can you tell if the flapper valve needs replacement? It is a cheap part that is easy to replace, but why waste the time if it's not necessary?
Also, the motor has become quite loud - sounds identical to the problem decsribed in post Whisper Quiet DW not quiet anymore. It is loud the whole time the dishwasher is running.
Would you replace the check valve first then the motor? Or would you replace both, since it's likely the motor is bad?
Also, do you think this series is kind of a lemon? There seem to be a lot of problems on these models at a relatively young age.
Last - I am new to repairing my own appliances, but have replaced my icemaker and a door latch - easily - after reading your blog. This is a very empowering blog - THANKS!!
Old November 7th, 2009, 09:02 AM
If the flapper is curved and not straight up & down, when you have it out, then its bad.
It sounds like your motor may be bad.
Here's the wash motor assembly for your model:
8534942
Here's the sump/wash motor assembly for your model(Comes complete with motor already installed):
Manufacturer's Number: 8535150
8535150
Page 17 Read 1-4 where it says this to change the motor:
Lower Spray Arm
drain flow and flapper valve GE4ME GE/Hotpoint 5 March 17th, 2008 12:19 PM
Norge dryer wont heat, Coils-gas valve? mnjhartke8t2v Dryers 9 November 20th, 2006 10:48 AM
bad valve? maytag msd2454gr bamabigfoot Maytag/Magic Chef/Admiral/Jenn-Air 15 November 11th, 2006 09:30 PM
Bosch 2042 (and others?) fill valve tip wapitiscat Bosch 1 August 9th, 2006 07:10 AM
Bad inlet valve? JoyMc59 Refrigerators & Freezers 4 April 11th, 2005 02:40 AM
