Now the oven light will not go off and when we try to heat up the oven, the "CLOSE DOOR" indicator on the display comes on. The oven will only heat up to about 180F or sometimes just stays on Lo. The door is fully closed, yet the "CLOSE DOOR" indicator is still on. Pressing the Oven Light button will not turn the oven light off. I have made sure the door is fully closed but the problem still exists. The only way to get the oven light to turn off is to flip the breaker switch to cut off power. When I turn the power back on, the oven light is off and the display blank. But when I press a temperature and hit start, the "CLOSE DOOR" indicator comes on and the oven light will not turn off again. Any ideas what could be the problem? |
Sounds like possibly a defective control board, that should be covered under warranty from KitchenAid.
Contact KitchenAid and let them know. Jake
I think you might be right.
I did a little exploring with my flashlight into the middle venting area where the blower was making the rattling noise. You can see back pretty far and actually see the blower running. I noticed that the door latch assembly has some wires going from it to the back near the blower. In fact, these wires were rubbing up against the blower fins. There was some slack, so I pulled the wires back toward me and away from the blower. Guess what? No more blower rattling noise. However, the wires are frayed where they were hitting the blower. I will bet this caused a short circuit and messed up part of the latch assembly switches or the control board itself. Seems like all this could have been easily prevented if the manufacturer had secured the group of wires instead of leaving slack for them to get back toward the blower. Does my assessment of the problem seem realistic? |
Yes, that sounds about right.
| Kenmore wall oven 911 4742590 Error Code F2 or F3 | jthomas119 | Sears Kenmore | 5 | March 16th, 2009 02:58 PM |
| Jenn-Air Convention Double Wall Oven (WW30430B) - F1 Error | rwhalen | Maytag/Magic Chef/Admiral/Jenn-Air | 1 | July 26th, 2008 09:09 PM |
| KitchenAid #kgsc308Lss0 Gas Range/conv oven error ‘Err’ can’t enter temp above 260 | ed_oertel | KitchenAid | 14 | March 25th, 2008 11:24 PM |
| kitchenaid oven - preheat and temp display problem | BTraut | KitchenAid | 8 | February 7th, 2008 06:16 PM |
| Error codes on built-in double oven model # RBD306PDQ14 | spthomas | Whirlpool | 10 | September 19th, 2006 12:05 AM |
