  #11
Old November 11th, 2009, 08:57 AM
Its alot easier when you remove the front door panel, (makes more room).
Read Page#17 here:
Where it says:
1. Remove the eight (8) screws securing the outer door panel to the dishwasher door frame.
(Fig. 3-7)
Remove the outer door panel from the door frame.
Then you can get to the drain pump motor easy, read #21 were it says:
Removing the Pump Motor
Here is the Drain motor:
Part#661658
Check to make sure the drain motor impellers are not broken.
thankdog (November 12th, 2009)
Old November 12th, 2009, 01:42 PM
thankdog is on a distinguished road
Thanks Jake.....looked at everything. Nothing seemed broken, clogged or out of the ordinary so I put it all back together and ran it. Just opened the door. Dishes clean. No water. Go figure.
At least now I know how to take it all apart if I ever need to again! Thanks for all your help - the photos and links were invaluable!
Lynn
Old November 12th, 2009, 02:02 PM
Sounds good Lynn.
Kirkland Signature - Not Draining - Model: SUD5100 D&M95 Whirlpool 7 September 2nd, 2008 03:31 PM
Maytag Washer Model MAV6000AWW draining problem svasudev Maytag/Magic Chef/Admiral/Jenn-Air 3 December 28th, 2006 07:48 AM
kenmore 80 - draining while agitating nasus Sears Kenmore 1 March 4th, 2006 08:57 AM
Kenmore 80 Series, Water Saver Model, Draining Problems ? Honeybee Sears Kenmore 1 November 27th, 2005 07:09 PM
Model 110 44832202 emorabito Sears Kenmore 4 September 18th, 2005 11:55 AM
