Old November 9th, 2005, 09:29 AM
Kathy is on a distinguished road
Default kitchen aid dishwasher model KUDS25SHBT1
Our repairman put a new water inlet assembly because it was leaking water onto the floor under the dishwasher. He even glued it in because the other repairman said that worked on his dishwasher. But the second time I ran the dishwasher it was leaking again. I have alarms and a couple pans under the unit now and the alarm went off. This dishwasher is five years old and is run about once a week.Otherwise it has been fine. The repairmen were very critical of the design of this part. Has anyone had any luck with this repair? Thank You!
Old November 9th, 2005, 09:51 AM
Are you talking about the water valve itself or where the water inlet comes into the machine on the left middle side?
Old November 9th, 2005, 09:55 AM
Default reply to Jake
Yes. It is on the back left wall. I just found out that the part has been revised to stop leakage, So I guess we will try the new part. Do you know if the new one works???The repairClinic.com has the number listed as 778221. I think it also goes by 675828.
Old November 9th, 2005, 10:03 AM
Looks like it has been revised,
Here is the one you need:
Water inlet assembly, revised to stop moisture from escaping
Yes, its Item#778221
Old November 9th, 2005, 10:11 AM
Default For Jake
Thank You, Jake. Do you have any experience with this new part or know anyone who has? Do you know how it has been revised?? Thank You!
Old November 9th, 2005, 10:15 AM
I haven't put this new revised one in, but it looks almost identical to the old style, but with changes made in it to keep it from leaking.
Jeff1 may have installed one of these.
Old November 9th, 2005, 04:59 PM
Default For Jeff
IF you installed the new type part, does it work better than the other one? Do you know what they changed? Thank You!
Old November 11th, 2005, 07:11 AM
Default WATER Inlet Assemby: 778221
Has ANYONE put this new part in??? THANK YOU FOR A REPLY OR YOUR KNOWLEDGE!!
Old November 11th, 2005, 09:35 AM
I have not changed one before....sorry!
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Kitchen Aid Dishwasher KUDI01TJBL0 wbice KitchenAid 2 June 5th, 2007 10:52 AM
Kitchen Aid Superba Ice chute freezing up---Model number not found johnnyk101 KitchenAid 2 May 6th, 2007 08:19 PM
Kitchen Aid carwasher44 Buy, Sell or Trade 0 December 29th, 2006 11:23 PM
Kitchen Aid Dishwasher KUDI01TJ Door seal comes out when I open the door johnr9q KitchenAid 1 November 13th, 2006 10:03 PM
Maytag model WU702 Dishwasher - NOISY Mark Gammell Maytag/Magic Chef/Admiral/Jenn-Air 2 August 11th, 2006 07:54 PM
