June 20th, 2010, 02:18 PM
test compressor to verify
Have Side by Side KitchenAid Refrigerator
Model KscS27Qfwh01 (zero one) Ser. SH2730744 MFG Date 6/98
W/ Compressor
Embraco EGS 90 HLP 20 LRA - R134a --- J98LP9UV
I Have read a couple of threads that seem to present a problem similar to the one on my sidebyside unit. That is my unit cools upon first connecting the unit to a live outlet upon startup but then never again seems to force itself into cooling again but you do hear the click, click, click of the unit attempting to place the compressor back into cooling again. Deduction and process of elemination places this problem for me as one caused by relay activating the compressor or at the compressor damage. One of the messages stated that the relay on the unit was white however the Tech sheets corrected this information for the particular model I have. The relay (labeled on the sheet as a PTC relay is black; it has blue and white wires connected to the unit and this is where I conducted the continuity test as described in resolving the problem in one of those threads above. At the 200ohm scale the test shows as an open. I conclude the relay is damaged as it also rattles; the second tech sheet is a drawing which shows a variable resistor running in between the test points for continuity on the outside of the PTC relay; this would be the connectors used for the blue and white wires. Is my conclusion correct, that is, the relay is likely the damaged part?
As for what is white next to the relay that would be the overload I am not sure on how to test this part but will assume is good for the time being my question here would be
Is it standard to replace this part in conjunction with the PTC relay?
Can I safely assume that the compressor is in good shape being that the unit cools upon startup (twices started and it reacted similarly) or do I have to test the compressor --somehow force it to start to verify it works before repairs?
The Embraco web site is not very specific as to describing the particular compressor so if anyone can provide more detailed info so as to attempt to force the compressor to start it would be appreciated if you post/reply. In particular I wanted to find out the horse power rating so as to determine if it was possible to purchase a 3 in 1 starting unit to test the compressor's operation. Markings on the unit (EGS, HLP) when used in a web search only return web sites with no technical info only sales related so far..
One further question if I may, is there a local to Houston or close to downtown area where I can purchase this part or for that matter any refrigerator parts for this unit, I also need the door gaskets for another unit my backup.
Any help appreciated thanks .....
June 20th, 2010, 04:48 PM
If your relay tested as open, then its bad.
Don't purchase the 3 in 1 kit, those do more harm to compressors than anything else.
Here's a link to appliance parts stores in the Houston Area:
houston appliance parts - Google Maps
But you can order them online as well.
Here's the relay for your model you can order:
Manufacturer part number 2262185 is RepairClinic item number 1026721
2262185
When you order the relay alone you will also need the overload as well:
Manufacturer part number 2183456 is RepairClinic item number 450529
By SomeGuyInBrazil in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: December 12th, 2009, 07:23 PM
By CDoble in forum Frigidaire/Electrolux
Last Post: July 8th, 2009, 11:38 AM
By chic in forum General Appliance Chat
Last Post: March 9th, 2008, 07:09 AM
By peanut3122 in forum Frigidaire/Electrolux
Last Post: December 1st, 2006, 12:08 PM
By MikeWalsh in forum Sears Kenmore
Last Post: August 2nd, 2005, 05:36 PM
Tags for this Thread
