Results 1 to 7 of 7
Thread: Rinse Light Flashes
    C6Silver is offline Member
    Jul 2010
    Los Angeles, CA
    Default Rinse Light Flashes
    Model Number: KUDS01DL
    Brand: KitchenAid
    I have a stainless steel model KitchenAid KUDS01DL.
    Today I noticed that the "rinse" light on the control panel flashes and no other control panel buttons worked. I unplugged the unit in hopes of resetting, but this did not clear the problem. When plugging back in the panel stays dead and no light blinks but after a while the rinse light begins blinking again.
    Interestingly, if I repeatedly press the drain button on the front it will eventually kick in and start the drain, but it takes repeated button presses for that to happen and still no other buttons on the panel (including the start button) work no matter how many times pressed.
    I am not sure if this is the control panel or the control board. I am confused as to what component needs to be replaced.
    Thanks for any help!
    Jul 2010
    Los Angeles, CA
    As an update. I peeled back the touch pad and also seated the ribbon cable again. Now the dishwasher start and drain buttons work at first press, however, the touch pad itself is totally dead with no lights working and no flashing rinse light either.
    Hope this adds something to the equation...
    Please double check your model#, your missing some digits at the end. The model# tag should be inside the dishwasher on the top or side tub frame.
    Yes, its your control panel thats bad, I will link you to the correct part once you post your complete model#.
    Here's the results I get:
    KUDS01DLBL0 UNDERCOUNTER DISHWASHER
    KUDS01DLBL1 UNDERCOUNTER DISHWASHER
    KUDS01DLBL2 UNDERCOUNTER DISHWASHER
    KUDS01DLBL3 DISHWASHER
    KUDS01DLBL6 UNDERCOUNTER DISHWASHER
    KUDS01DLBL7 UNDERCOUNTER DISHWASHER
    KUDS01DLBT0 UNDERCOUNTER DISHWASHER
    KUDS01DLBT1 UNDERCOUNTER DISHWASHER
    KUDS01DLBT2 UNDERCOUNTER DISHWASHER
    KUDS01DLBT3 DISHWASHER
    KUDS01DLBT6 UNDERCOUNTER DISHWASHER
    KUDS01DLBT7 UNDERCOUNTER DISHWASHER
    KUDS01DLSP0 DISHWASHER
    KUDS01DLSP1 UNDERCOUNTER DISHWASHER
    KUDS01DLSP2 UNDERCOUNTER DISHWASHER
    KUDS01DLSP3 UNDERCOUNTER DISHWASHER
    KUDS01DLSP6 UNDERCOUNTER DISHWASHER
    KUDS01DLSP7 UNDERCOUNTER DISHWASHER
    KUDS01DLSS0 DISHWASHER
    KUDS01DLSS1 UNDERCOUNTER DISHWASHER
    KUDS01DLSS2 UNDERCOUNTER DISHWASHER
    KUDS01DLSS3 UNDERCOUNTER DISHWASHER
    KUDS01DLSS6 UNDERCOUNTER DISHWASHER
    KUDS01DLSS7 UNDERCOUNTER DISHWASHER
    KUDS01DLWH0 UNDERCOUNTER DISHWASHER
    KUDS01DLWH1 UNDERCOUNTER DISHWASHER
    KUDS01DLWH2 UNDERCOUNTER DISHWASHER
    KUDS01DLWH3 DISHWASHER
    KUDS01DLWH6 UNDERCOUNTER DISHWASHER
    KUDS01DLWH7 UNDERCOUNTER DISHWASHER
    Jul 2010
    Los Angeles, CA
    Thanks very much for the reply. Sorry about the truncated model number. I took it off of the manual which I realize now is probably used for a bunch of models...
    From inside the dishwasher: KUDS01DLSS0
    Thanks again!
    Here's the control panel for your model you can order here:
    Manufacturer's Number: 8531257
    Jul 2010
    Los Angeles, CA
    Thanks, Jake. I suppose there is no way to just replace to touch pad? I put a multimeter on the ribbon cable that runs to the touch pad and there does seem to be power there. So the issue appears to be just the touch pad itself. You hate to replace the entire apparatus for $200 when all you need is the pad....
    Thanks.
    Unfortunately, you have to replace the complete control panel.
  1. KUDS01DLSS0 rinse light blinking
    By Jeff N in forum KitchenAid
    Last Post: November 20th, 2010, 11:25 PM
  2. KUDM01TJBS0 Rinse Only - Cancel/drain flashes
    By wkillham in forum KitchenAid
    Last Post: March 1st, 2009, 09:52 AM
  3. Replies: 24
    Last Post: February 21st, 2009, 10:22 PM
  4. KUDM Normal Light Flashes Constantly
    By luv2pla in forum KitchenAid
    Last Post: August 27th, 2007, 09:38 AM
  5. Maytag MDB6600AWB Rinse Only Light
    By dojo13 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 9th, 2007, 09:28 AM
