Old December 14th, 2005, 06:59 PM
dstahl1965 is on a distinguished road
Default KitchenAid Icemaker won't harvest
I have a KitchenAid side by side fridge with the ice container in the door. The ice maker tray is full and completely frozen but it won't harvest. Any idea what the problem might be. Of course it is 15 months old, so it is out of waranty
Old December 14th, 2005, 08:45 PM
Your KitchenAid Ice Maker works the same as the Whirlpool Brand.
Here is a thread on the display light and the codes to test:
[FIXED] Kenmore & Whirlpool Ice Maker LED Blinking Codes & Online I/M In-Door Repair Manual
Old December 15th, 2005, 04:25 AM
Default LED is a constant red
I checked the LED and it is a constant red. If I put my finger over the hole to obstruct the optics and the LED flashes. So, it appears my optics are fine. Any other suggestions?
Old December 15th, 2005, 11:31 AM
Are the ice maker plastic ejector blades pointed at you at about the 1 or 2 o'clock position?
Old December 15th, 2005, 01:06 PM
Default Blades
The blades are slightly lower than level (3), so probably between 3 and 4.
Old December 15th, 2005, 04:09 PM
If its that low, you may have a bad ice maker module. Since these are basically all electronically controlled, i would recommend Sears or another appliance repair company come and fix it.
Old December 15th, 2005, 05:33 PM
Default Good fortune
I just called KitchenAid and asked them to covering it under waranty since it was only a month out of waranty. They were very good about it and agreed. BTW, how much is an ice maker? It seems straighforward to install.
Old December 15th, 2005, 10:15 PM
A new ice maker is about $120-$150 for your model.
Glad KitchenAid will cover it under warranty.
Kitchenaid KSRX25FNST01 Icemaker problems zenla13 KitchenAid 8 June 30th, 2007 10:02 AM
Kitchenaid KSRB27QGSS01 Icemaker khefron KitchenAid 12 May 6th, 2007 08:23 PM
Kitchenaid Icemaker KSCS25I ThomasA KitchenAid 3 November 29th, 2006 12:14 AM
Kitchenaid Icemaker won't harvest icecat14 KitchenAid 1 February 7th, 2006 08:35 PM
Kitchenaid Free Standing Icemaker KUISI5NRHB6 rsirmans KitchenAid 3 December 10th, 2005 09:14 AM
