September 23rd, 2011, 02:10 PM
KitchenAid Oven blew fuses, now get F2E0 error - HELP!
We have a KitchenAid Superba (KEBS278DBS6) double oven, which had the famous "Cleaning Cycle blew my fuses" issue where we put the oven into self-cleaning mode, which blew the thermal and thermostatic fuses on the oven. Thanks to help on many threads here, I was able to get the oven open, then replaced the fuses, as well as the blower. Everything "appears" to be fine now, except every time we turn on the oven, after about a minute or two it shuts off and shows error code F2 E0. From looking at the manual, it looks like that means there is a connection error between the control board and the keypad. I've tried cleaning the connection, as suggested before, but no matter what I do I always get that error now. So I figured I would replace the keypad. Unfortunately it's no longer made and can't be replaced. I've searched everywhere.
We're being told that our only choice is to dump this oven and get a new one. What I have a big problem with is, everything seems to work fine on the oven! I can't believe we're gonna have to spend $2-3k for a new oven, when the only issue is the connection between the keypad and the control board! I'm an IT guy, I undestand computer hardware, and this keypad isn't "broken", it still works fine for setting the time, setting a timer, putting in a temperature, etc.
So I'm wondering if there's ANYTHING I can do to save this oven? Seems like an unbelievable waste to toss it because of this error code. Is there any way to bypass the error? Can anything be done?
Thanks so much for your help, I really appreciate it!
Eddie
September 24th, 2011, 01:42 AM
Hi Eddie,
Yes, its a bad control panel assembly and your correct, Its No Longer Available.
This is a 1998 double wall oven. The average life of appliances now is only 8-12 years.
So 13 years is not bad.
The days of appliances lasting 20-30 years is long gone unfortunatly.
By djgogga in forum KitchenAid
Last Post: October 29th, 2012, 02:30 PM
By twinter20 in forum KitchenAid
Last Post: June 19th, 2012, 01:40 PM
By carolann in forum KitchenAid
Last Post: September 8th, 2011, 11:13 AM
By Stover23 in forum KitchenAid
Last Post: November 9th, 2009, 09:54 PM
By ed_oertel in forum KitchenAid
Last Post: March 26th, 2008, 12:24 AM
Tags for this Thread
