Results 1 to 10 of 14
Thread: Superba Electric Built-in Double Oven - Lower Oven Doesn't Work
    allanr is offline Premium Member
    Sep 2009
    Catonsville, MD
    Default Superba Electric Built-in Double Oven - Lower Oven Doesn't Work
    Model Number: KEBC207KBT0
    Brand: KitchenAid
    My daughter recently moved into a house that has a Kitchenaid Superba 30" Electric Built-in Double Oven (KEBC207KBT0). The top oven works fine, but the bottom oven does not. I'm at step 1 of troubleshooting this problem and I'm looking for suggestions on how to locate the cause of the problem. I.E. what tests can I perform to isolate the problem? (e.g. thermostat, switches, etc.) Thank you for any assistance with this problem.
    Can you explain further what happens when you start the bottom oven? Does the clock control do anything?
    Also try the broil on the bottom oven and see if that works.
    Sep 2009
    Catonsville, MD
    Hi Jake,
    Yes, now I can provide more info -- I finally arrived at my daughters house and see the problem for myself.
    When I turn the bottom oven on bake, the display says it is on and the time it started and you can hear it running, but it does not get hot... or even warm. I tried the same thing with broil and got the same result.
    Could that be a thermostat problem or something to do with the elements? If it is an element problem it seem strange that both would be affected. So I suspect there is probably an underlying issue I'm not aware of.
    Thank you for your reply. You've assisted me in the past so I have faith you can do it again.
    There is a oven shutdown thermal fuse that you'd need to check for continuity. Turn the breaker off to the oven first before accessing and testing it.
    Its located in the very back #37 here:
    Here's #37 for your model:
    Manufacturer part number 9759242 is RepairClinic item number 1061375
    Sep 2009
    Catonsville, MD
    Jake, I was finally able to remove the oven from the cabinet and test the thermal fuse. No continuity at all.
    I have ordered another thermal fuse and will install it next week.
    Thank you once again for your assistance. I will let you know if I encounter any additional problems.
    Sincerely,
    Allan Rabune.
    Sounds good Allan, keep us posted when you get it installed.
    Allie67 is offline Member
    Apr 2012
    Colorad
    I believe I have this same double oven in black. It was used and put into my house but is missing the model number off the sticker on the inside of the door. It is missing the trim piece at the bottom of the lower oven where it overlaps onto the front of the cabinet where it is installed. Can you direct me to the right piece so I can order? Thanks!
    Without a model# it will be impossible for me to locate that trim part#.
    jaxnana is offline Member
    Jun 2012
    Jacksonville
    Jake my son's 30" double oven kitchen aide superba just stopped. No power at all. Breaker did not trip. Everything else in the kitchen working. Oven is probably 12- 13 years old. Do you think this is a fuse problem or what?
    Yes, sounds like the fuse inside it went out, whats the model# of it?
    Click here to locate it: Help Me Find My Model Number - RepairClinic.com
  1. Replies: 3
    Last Post: August 16th, 2011, 06:31 PM
  2. whirlpool double wall oven doesn't work
    By Barreras in forum Whirlpool/Roper
    Last Post: October 9th, 2008, 09:19 AM
  3. Kenmore Electric Built-in Oven 91141185591
    By badonkadonk in forum Sears Kenmore
    Last Post: August 28th, 2007, 10:08 AM
  4. self cleaning doesn't work on my kenmore built-in oven
    By gerg36000 in forum Sears Kenmore
    Last Post: May 8th, 2007, 12:24 PM
  5. Error codes on built-in double oven model # RBD306PDQ14
    By spthomas in forum Whirlpool/Roper
    Last Post: September 19th, 2006, 01:05 AM
Tags for this Thread
