Results 1 to 4 of 4
Thread: kitchenaid dishwasher won't drain or finish cycle. XXXX suds inside
    kcsunshine is offline Member
    Nov 2011
    conyers,ga
    Default kitchenaid dishwasher won't drain or finish cycle. XXXX suds inside
    Model Number: KUDC25SH
    Brand: KitchenAid
    Age: More than 10 years
    Ran dishwasher and noticed A LOT of suds seeping out of the bottom. The whole inside was full of suds but the detergent dispenser had not released the detergent yet. Now there is about 3 inches of water sitting in the bottom and won't drain. Tried to let it finish the cycle but it just turns off.
    Have you noticed suds in it before, but not to that extent?
    You'll need cold water to flush the suds out. Just get a big container and fill it with cold water from your sink and pour it in your dishwasher and put your dishwasher on drain and see if it flushes it all out, you may need to repeat this process several times.
    Nov 2011
    conyers,ga
    This has never happened before. Suds were running onto floor with door closed! I put a fan near the dishwasher until it dried up the suds. Then I ran a short wash with NO detergent and it was fine. Then I ran a normal cycle with detergent and it was fine. Thanks for your help! Hope that doesn't happen again!
    Ok, thats very odd, don't know what would of caused that then.
  1. Bosch dishwasher will not finish cycle
    By MrMark52 in forum Bosch
    Last Post: March 15th, 2013, 10:18 AM
  2. Frigidaire Dishwasher won't finish cycle
    By swebeaux in forum Frigidaire/Electrolux
    Last Post: October 6th, 2011, 10:00 PM
  3. DU1050XTPQ3 Dishwasher Will Not Finish Cycle
    By JTech in forum Whirlpool
    Last Post: November 27th, 2008, 05:47 PM
  4. KitchenAid Ensemble - wont finish cycle
    By GregRussell in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: May 24th, 2008, 11:51 PM
  5. Kenmore Dishwasher Will Not Finish Cycle
    By MaryT in forum Sears Kenmore
    Last Post: November 13th, 2007, 10:39 AM
