Results 1 to 2 of 2
Thread: Oven will not heat up!
    Jason142 is offline Member
    Feb 2006
    DALLAS
    Default Oven will not heat up!
    I have twin ovens and recently I set them both to clean. following the cleaning process neither of them will heat up either on bake or broil but both ovens are working mormally with that exception< fans come on when set to bake or broil just no heat!
    Any help would be much appreciated.
    Thanks!!
    Jan 2006
    Toronto, Canada
    Smile
    Quote Originally Posted by Jason142
    Thanks!!
    Hello Jason
    It sounds like your high limit sensor has failed during the self clean cycle. If it has it could be due to a couple of reasons. Remeber the high temp sensor is only there for safety. IF the Oven temperature climbs high enough, the sensor will open cutting one line out of the 220 volt circuit to your Range. Reply with your model number and I will examine the schematic and be able to give you a more detailed responce.
  1. Replies: 9
    Last Post: May 14th, 2011, 08:37 AM
  2. Magic Chef Gas Wall Oven won't heat
    By mndzab in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 3rd, 2011, 07:39 PM
  3. GE double oven - no heat
    By Kelli in forum GE/Hotpoint
    Last Post: March 5th, 2007, 11:40 AM
  4. Replies: 1
    Last Post: September 29th, 2006, 10:41 AM
  5. oven microwave combo won't heat
    By jrmc49@excite.com in forum GE/Hotpoint
    Last Post: January 15th, 2006, 05:23 AM
