Results 1 to 4 of 4
Thread: Kitchen Aid
    Nobody is offline Member
    Aug 2012
    Canada
    Default Kitchen Aid
    Model Number: KUDE70FVSS3
    Brand: KitchenAid
    Age: Less than 1 year
    We bought the dishwasher from Sears Outlet store and it was still in box and never used. We installed it awhile ago and it was working properly for 4 or 5 time, then suddenly it doesn't work anymore, we have checked the wire and it work just fine and we could not turn it on.
    We would appreciate your help because it is brand new dishwasher.
    So nothing works on it at all? No lights, No sounds? Like its dead?
    First check your main power connection where it comes in from your house electrical, its in the metal junction box below your dishwasher, take the front bottom access panel off then you should see the junction box.
    Turn the breaker off to your dishwasher first, then open the junction box and check your wire nut connections, I have see many installers not tighten those 2 wire nuts tight enough and thus you get arcing and you get low or no voltage to your dishwasher.
    Also you need a volt meter to make sure your getting 120 volts there as well.
    Aug 2012
    Canada
    Nothing work at all,
    we did check the wire and it work fine and got all 120 volts there. We also checked the fuse and it works okay. It could be the board (computer programming) in the dishwasher is not working properly?
    Its hard to say, there is no way to check that board with it dead like it is now, since its so new you will need to get KitchenAid to come out and see whats going on.
  1. Kitchen AID
    By umer in forum KitchenAid
    Last Post: February 27th, 2012, 09:09 AM
  2. Kitchen Aid
    By RWaltz in forum KitchenAid
    Last Post: May 16th, 2010, 11:35 AM
  3. Kitchen Aid Dud
    By Clay Mangum in forum KitchenAid
    Last Post: November 2nd, 2009, 07:00 PM
  4. Kitchen Aid
    By carwasher44 in forum Buy, Sell or Trade
    Last Post: December 30th, 2006, 12:23 AM
  5. Kitchen Aid needs first aid
    By Bobby52 in forum KitchenAid
    Last Post: June 6th, 2006, 12:16 PM
