Results 1 to 5 of 5
Thread: Kitchenaid gas cooktop lighting problems
    howardih is offline Member
    May 2006
    wilmington, de
    Default Kitchenaid gas cooktop lighting problems
    My Kitchen Aid 5-burner gas cooktop does not light up properly. When starting the sparking procedure, it takes a number fo attempts before the burner finally lights. Once the burner lights, all other burners light with no problem. This happens when I choose any of the five burners to light up first. When holding a match to the unlit burner during the sparking process, I do seem to have very low pressure gas flow, as the burner lights up in the low pressure "protected mode" (i.e., just a small flame). I'm thinking that there may be a problem with the Maxitrol pressure regulator. Note that my outdoor barbeque and gas fireplace both fire up with no problems so I know there is no pressure problem in the gas line itself. Any ideas on what may be the problem?
    Whats the model#? It does sound like you have a problem with your regulator in your range.
    May 2006
    wilmington, de
    It is the KGCS166GSS series. I don't have the numeric code following the "GSS" designation but it is the 36 inch "stainless steel" model sold by Lowe's.
    I not familiar with this model.
    The RepairGuru may be able to help you more on this unit.
    jmshaffer's Avatar
    jmshaffer is offline Appliance Tech
    Mar 2006
    pennsylvania
    are you natural gas or LP?
  1. KitchenAid Range/Oven F2:E1 Error, Ignitor problems
    By twinter20 in forum KitchenAid
    Last Post: June 19th, 2012, 01:40 PM
  2. Kitchenaid KGRT507 gas range slow to heat
    By Bobbie Hall in forum KitchenAid
    Last Post: March 16th, 2007, 08:30 PM
  3. Whirlpool super capacity 465 gas oven not lighting
  4. Kitchenaid cooktop not heating water adequately
    By robinbass@comcast.net in forum KitchenAid
    Last Post: April 9th, 2006, 11:21 PM
  5. Rear Burners Kitchenaid cooktop not woking
    By pnourse in forum KitchenAid
    Last Post: January 20th, 2006, 12:50 AM
