Results 1 to 10 of 14
Thread: Changing the rings around burners
    mrm
    mrm is offline Member
    Nov 2005
    Seattle
    Default Changing the rings around burners
    I have Kitchen Aid stove model KGRT507 and the plates around the burners are in need of replacing. How do I take them apart? Any help would be appreciated.
    KGRT507 is only a partial model#, we need the complete model# to help you out.
    mrm
    Nov 2005
    Seattle
    Hi Jake:
    The numbers KGRT507 and KGST307 are on the Use and Care Guide. I looked all around the stove/oven and can't not see any number. Any idea where it would be.
    MRM
    I found alot when I input KGRT507, like all these:
    KGRT507BAL1 30" GAS SLIDE-IN RANGE KITCHENAID
    KGRT507BAL2 30" GAS RANGE KITCHENAID
    KGRT507BAL3 30" GAS RANGE W/CONVECTION OVEN KITCHENAID
    KGRT507BAL4 GAS RANGE KITCHENAID
    KGRT507BBL0 GAS RANGES KITCHENAID
    KGRT507BBL1 30" GAS SLIDE-IN RANGE KITCHENAID
    KGRT507BBL2 30" GAS RANGE KITCHENAID
    KGRT507BBL3 30" GAS RANGE W/CONVECTION OVEN KITCHENAID
    KGRT507BBL4 GAS RANGE KITCHENAID
    KGRT507BWH0 Range (gas)* KITCHENAID
    Look in the oven door, and at the bottom of your range, when you pull out the bottom stoage drawer. It should have a tag on the left side behind that storage drawer, near the left leg.
    mrm
    Nov 2005
    Seattle
    Smile
    Hi Jake:
    Thank you I founded. KGRT507FWH0. It is slide-in stove/convection oven
    M
    What part on this parts diagram do you need?:
    http://www3.sears.com/imaging/ImageP...&titleID=00001
    mrm
    Nov 2005
    Seattle
    Hi Jake:
    11 and 12. How do we take it out?
    MRM
    You should see 2-4 screws that hold it into place once the burner caps are removed.
    Do you see them?
    mrm
    Nov 2005
    Seattle
    Hi:
    No. When the burner cap is off, I see one screw on top. And taking it out. did not do anything. Is it possible the metal part under the burner cap is a twist on ?
    MRM
    Yes, its possible. Its been awhile since I took one of these off, I would have to look at it myself to see for sure. If you have access to a digital camera and could upload the photo of it here, that would help alot.
  1. Replies: 3
    Last Post: September 20th, 2006, 08:42 PM
  2. 79046802991 front burners on when turned OFF!
    By scifinerd in forum Sears Kenmore
    Last Post: June 28th, 2006, 11:18 AM
  3. Magic Chef burners pop and sputter
    By Snowshome in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 7th, 2006, 09:54 AM
  4. Hotpoint Ceramic - No power to burners or stove
    By rb787w in forum GE/Hotpoint
    Last Post: April 3rd, 2006, 11:36 AM
  5. Rear Burners Kitchenaid cooktop not woking
    By pnourse in forum KitchenAid
    Last Post: January 20th, 2006, 12:50 AM
