LinkBack (2) Thread Tools Search this Thread Display Modes
  #11
Old April 14th, 2007, 07:53 AM
alan12 is on a distinguished road
Default blinking light
My bad. I replace board after the washer stopped the first time in response to the add a dish light blinking. After that it was working great but never finished(the first usage) because the washer stopped and the clean light started to blink 7 times.
Also I looked in the link you provided for the code to reset however I didnt see any for the led blinking 7 times. Should I use the to reset if in Demo mode? Thank you for your help.
Old April 14th, 2007, 07:56 AM
Just a note. It turns out the parts list you provided above is where I purchased my control board.
Old April 14th, 2007, 08:05 AM
Ok, thats very odd these 2 problems would happen at once.
I know it doesn't say anything about the clean light blinking 7 times, but the links I posted in the beginning of this thread explains about it.
I just posted that service sheet link so you can reset the blinking clean light error code, your model may have High Temp Scrub or Sani Rinse for the options on the keypad to choose from, then you press the buttons in sequence like it shows you.
Old April 14th, 2007, 08:10 AM
OK I didnt scroll my page over to the right. Is there a certain way to do this? When I try either option nothing happens hightemp -air or sani air. thank you for helping.
Old April 14th, 2007, 08:45 AM
You have to do it twice in a row, the same sequence.
Old April 14th, 2007, 08:48 AM
Thank you for all your quick responses. I did two times in a row and nothing happens. SHould I just get a new washer?
Old April 14th, 2007, 08:52 AM
Might help....
http://www.applianceaid.com/whirlpool_dishwashers2.html
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old May 23rd, 2007, 01:54 PM
moeneek is on a distinguished road
Default Thank you! This helped
Thank you for the website. I have a Whirlpool Quiet PartnerII that had the blink 7 times problem and this info helped.
Old July 15th, 2007, 08:09 AM
mdandrea is on a distinguished road
My KUDSO1VMSS7 had the blinking issue. I did the button seq that started the machine again. Unfortunately, the machine does not work.fficeffice" />>>
The tub fills with water but the jets never come on. There is a humming sound but the jets don't turn. After several minutes, the water is removed and more water is added. The humming comes back but no jets. >>
Any idea what is going on? Is the motor dead? >>
Another thing, when I open the door, the water level is right below the element and a sizzling sound is being made by the water. Is this the proper water level? Is this normal?>>
Old November 5th, 2008, 01:03 PM
Team Beal is on a distinguished road
Thumbs up Reset Sequence Worked!!!
Rachit,
Thanks for the tip. I tried your 'reset sequence' on our Kitchen Aid KUDI01ILBS6I was able to run a 'Normal/Start' wash cycle for the first time in a month. Woo Hoo!
Note: our unit had shorted out due to a water leak from the 'Overflow' sensor unit in the bottom of the tub. I guess it invoked a 'brain dump' from the short.
Thanks for saving me $115 and the trouble shooting time.
-Team Beal
LinkBack to this Thread: http://www.applianceblog.com/mainforums/kitchenaid/5671-clean-light-flashes-7-times.html
Posted By For Type Date
Blinking clean light. - FixYa This thread Refback September 19th, 2009 04:14 PM
We have a quiet partner III and the clean light is blinking and won't let us do start another cycle! I t This thread Refback September 5th, 2009 05:04 AM
Qiuet Scrub Clean light and Cancel light Timecloud KitchenAid 20 October 26th, 2007 09:33 AM
KUDP more questions for clean light blinking Gradstudent KitchenAid 1 March 23rd, 2007 09:10 PM
Whirlpool Quiet Partner I DU1055XTPS3 - clean light flashing dazedandconfused Whirlpool 1 December 13th, 2006 12:11 AM
Kitchen Aid Clean Light Blinks 7 Times CaliMan KitchenAid 11 February 8th, 2006 10:48 AM
Kenmore elite 665 green clean light flashing minty Sears Kenmore 3 December 26th, 2005 08:55 AM
