December 14th, 2006, 03:45 PM
KitchenAid Range F3 error
Have a KitchenAid Electric Slide-In/ Drop-In Range Model number KEDC205Y that recently give a F3 error and a loud buzz. Cancel takes care of the buzz. Oven then does not work. What is the cause of the F3 error? Also, once it gave a F2 error code. This has just started to happen and I am afraid to use the oven until I understand the problem.
Help!
December 14th, 2006, 08:20 PM
Yes, the F3 and F2 indicate a bad control board and oven sensor.
Here is your control board:
Electronic clock control
Here is your oven sensor:
Oven temperature sensor
December 15th, 2006, 06:00 AM
Is it both parts - in which case I buy a new stove - or could it be just one part? Can I tell which part is bad?
December 15th, 2006, 10:42 AM
Yes, you would need a ohm meter to ohm your oven sensor. At room temperature your oven sensor should read 1100 ohms. If it does, then you would just need the control board.
You can get an ohm meter at your local radio shack or hardware store or online at the link in this post.
Jae
December 18th, 2006, 05:57 PM
Where can I find a repair manual for the KitchenAid Electric Slide-In/ Drop-In Range model KEDC205Y? Have not found one on the blog. Need to learn how to remove/ install the parts discussed.
Thanks.
December 18th, 2006, 10:04 PM
Sorry, I have been looking online myself for a repair manual for your model, I'm not able to locate one.
December 19th, 2006, 11:49 AM
Did the check of the sensor and it reads 1,097 ohms. I assume that is close enough that the problem is the control board?
Thanks - have a great holiday.
December 19th, 2006, 07:31 PM
Yes, thats close enough. Its your control board then.
Merry Christmas & Happy Holidays!
By twinter20 in forum KitchenAid
Last Post: June 19th, 2012, 01:40 PM
By Katy in forum KitchenAid
Last Post: February 12th, 2011, 10:51 PM
By miker5 in forum KitchenAid
Last Post: March 29th, 2006, 01:58 PM
By Trixie in forum Whirlpool/Roper
Last Post: January 29th, 2006, 12:25 PM
By Shrk2th in forum KitchenAid
Last Post: September 22nd, 2005, 04:52 AM
