My KitchenAid dishwasher KUD10ILBL2 is acting up wierd since last couple days. Sometime the START button would not work while other function buttons are working ok. I've searched posts that are related to this problem but seems no real solution to this issue. I followed all previous posts, reset the power for hours, opened the control pannel and checked continuity for door switch and thermal fuse and found them ok. I also removed all wires and ribbon from the control board then hooked them back up making sure all connections are good. But the START button is still not working. This morning, I decided to press the START button again and OMG it work like normal... I really don't know why sometime it work and sometime it does not work? and I'm sure it will not work later tomorrow. Back to the question, how do I know when the thermal fuse goes bad? can I do the continuity check? any more troubleshoot on this issue? Thanks Pat |
tho check the thermal fuse, disconnect the harness and check with ohmeter. You should have contiuity. Also check the door switch(es) for any visible corrosion or discolouration. I would replace if needed.
If the thermal fuse was bad, it wouldn't start at all at anytime.
It sounds more like your control panel keypad is starting to go bad. Please check your model# again, I can't get any parts information diagrams to pull-up. Jake
Hi Jake,
The model is KUDI01ILBL2. The START button is working now but who know if it does tomorrow... Thanks Pat |
Here is the parts diagram for your model: KUDI01ILBL2 Diagram#1 part location #1 is your control panel assembly if you need to order it. Glad its working good again now. ![]() Jake
| double oven blows thermal fuse | janrog300 | Whirlpool | 12 | September 30th, 2007 12:25 AM |
| thermal fuse keeps blowing | chanchamone | KitchenAid | 2 | July 9th, 2007 10:55 AM |
| Kenmore 70 Series - Thermal Fuse ? | BeccaSue | Sears Kenmore | 7 | September 12th, 2006 11:57 PM |
| Kenmore 70 Series - Thermal Fuse Keeps Blowing Out | rebepany | Sears Kenmore | 5 | March 16th, 2006 07:56 PM |
| Kenmore keeps blowing thermal fuse. HELP! | tjs | Sears Kenmore | 7 | December 20th, 2005 06:16 AM |
