Old May 21st, 2007, 09:21 PM
zenla13 is on a distinguished road
Default Kitchenaid KSRX25FNST01 Icemaker problems
My Kitchenaid side by side's ice maker stopped working yesterday. The unit's 2 years old and has been running perfectly. Does the same solution apply to this model as some of the previous models mentioned here? Would the water filter not being changed have anything to do with it?
Old May 21st, 2007, 11:46 PM
Hi zenla13,
It could be a number of different things. That model uses an electric eye to monitor the ice in the bucket. When it's full, it shuts off the ice maker. If any one of those part fail the ice maker would stop. I want to make sure I understand you, the ice bucket auger and the dispenser are working fine and you can get water through the water dispenser but the ice maker is not making ice cubes. Is this correct?
Rick
Old May 22nd, 2007, 06:58 AM
Hi Rick,
The ice bucket is empty, right now. If I were to put ice in the bucket, the auger would dispense the ice through the door. I am able to get water through the dispenser. Any thoughts? Thanks.
Gerry
Old May 22nd, 2007, 07:22 AM
Gerry,
Start by checking your water valve. It's possible the solenoid has failed and the ice maker isn't getting any water.
Rick
Old May 22nd, 2007, 07:50 AM
The water valve located behind the refrigerator where it connects to the water line?
Gerry
Old May 22nd, 2007, 05:13 PM
Gerry,
Yes, thats correct. The water valve has two solenoids on it. One is for water and the other is for the ice maker.
Rick
Old May 23rd, 2007, 11:36 PM
Here is the water inlet valve for your model:
Old June 30th, 2007, 06:58 AM
Default Problem solved
Thanks for all the input and feedback! After all that, I decide to try something different. I noticed a black rubber piece by the water outlet near the ice tray. I squeezed it and thought it felt hard, too hard for the kind of rubber it was. I ran a blow dryer over it for a few minutes and sure enough, a frozen piece of ice came out of it. Problem solved. My icemaker's working like new again. I turned the thermostat on the freezer down a little so it doesn't occur again. Hopefully that's the end of it. Again, I appreciate all your time!
Gerry
Old June 30th, 2007, 10:02 AM
Gerry,
Glad you got it working
Rick
kitchenaid superbra icemaker problems piac KitchenAid 4 January 21st, 2007 10:35 PM
KitchenAid Range/Oven F2:E1 Error, Ignitor problems twinter20 KitchenAid 3 November 12th, 2006 10:08 AM
Kitchenaid Icemaker won't harvest icecat14 KitchenAid 1 February 7th, 2006 08:35 PM
Problems with icemaker. Loueloui Frigidaire/Electrolux 1 December 27th, 2005 12:18 AM
Kitchenaid Free Standing Icemaker KUISI5NRHB6 rsirmans KitchenAid 3 December 10th, 2005 09:14 AM
