Results 1 to 4 of 4
Thread: KitchenAid Superba Oven Dim Control Display
    Arnhemjim is offline Member
    Jun 2007
    Sun Lakes, Arizona
    Default KitchenAid Superba Oven Dim Control Display
    We have a KitchenAid Superba double electric oven (KEBS207DBL9), installed new in 2000. Recently oven was run in self-clean mode. Oven would not turn off and tripped breaker. Technician said it was a “runaway” condition probably caused by a failed relay in the self clean circuit. The Control Power Transformer, Lamp Transformer, Thermal Fuse to Electronic Control Panel (at P19), Oven Shutdown Thermal Fuse and finally the entire Electronic Control Panel, have all been replaced. The Electronic Control Panel and both ovens are functional, however the LED displays (both full Control Panel on left and Clock/Timer on right) are very dim. Any diagnosis or ideas would be greatly appreciated.
    Did they replace your microcomputer? if not, then thats what will need to be replaced.
    Jun 2007
    Sun Lakes, Arizona
    The full Electronic Control Board, e.g. microcomputer (the specific part pictured in your reply), has been replaced twice. Each replacement board has shown the same dim display. Any other thoughts?
    Jim
    Nope, don't know what else could be causing it, sorry.
  1. SVD48600 Display Dim
    By jodigirl in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 11th, 2007, 11:02 PM
  2. Kitchenaid kebs208dss10 double oven trouble
    By Ann Foust in forum KitchenAid
    Last Post: April 5th, 2007, 09:20 AM
  3. KitchenAid Superba KEMS307D8S6 Oven problem
    By jbow345305 in forum KitchenAid
    Last Post: March 24th, 2007, 09:32 PM
  4. Replies: 9
    Last Post: February 9th, 2007, 04:21 PM
  5. Kitchenaid Oven F3 Code
    By DJUecker in forum KitchenAid
    Last Post: February 20th, 2006, 07:21 PM
