Results 1 to 5 of 5
Thread: Maytag performa washer fills...and that all, folks!
    msubobcats is offline Member
    Aug 2007
    Purcell, MIssouri
    Default Maytag performa washer fills...and that all, folks!
    Water will fill to desired level, and then nothing. No sounds, no movement, zero. What I do hear is the sound like the whole washer having just shot craps.
    It's about 8 years old, and no other trouble. I have drained the water from the tub, and then re-filled it to make sure. The washer will fill, then die.
    I don't suspect it's the lid switch, because I know the washer would previously agitate with the lid open. Can a fuse be blown somewhere? I also doubt this because the washer does operate, at least a little bit (fills) so power is getting to the machine.
    Any ideas? I suspect 8 years is the shelf life and it's time to spend $ on a new one ...
    Go Cats
    Possibly the lid switch, timer or motor.
    Average life is about 8-15 yrs. old nowadays.
    Whats the model# of your washer? its located inside the lid or on the top console.
    Aug 2007
    Purcell, MIssouri
    Default There will be a delay
    on getting the model #. I will have that info this evening sometime and post it then...Thanks for the help...
    Go Cats
    Aug 2007
    Purcell, MIssouri
    Default OK, Thanks for the patience
    Maytag Performa
    Model # 2500AAE
    Go Cats
    Pegi at Sams is offline Appliance Tech
    Oct 2005
    Wichita Falls, Texas USA
    I would suspect either a bad lid switch or a fill level switch, either could cause it to fill and go dead, that does not look like a proper model number, believe should have some letters first before the numbers...
