Old August 21st, 2007, 08:11 AM
gjinc is on a distinguished road
Thumbs up Maytag side by side
I have a Maytag side by side that was leaking water on the floor.
I de-iced the drain like I saw in a few other posts and would like to
know what causes the drain to freeze??
Is there something that I need to do or fix to prevent this from happening again??? or does it just happen every now and then???
Thanks!!!
Greg
Old August 21st, 2007, 10:14 PM
You might want to get something to run down the drain line, I use a evaporator cooler spider snake:
http://www.azpartsmaster.com/shopazp...LR4690%29.html
Old August 22nd, 2007, 12:48 AM
Ok I will go see if any of the hardware stores have anything like it
Old August 22nd, 2007, 09:58 AM
Ok, sounds good.
Maytag Model MSD2657HEQ fridge side warm robivi3 Maytag/Magic Chef/Admiral/Jenn-Air 5 June 9th, 2007 01:29 PM
Maytag MSD 2756 GE refrigerators side not cooling goforit Maytag/Magic Chef/Admiral/Jenn-Air 1 July 16th, 2006 12:17 AM
Maytag Side by side leaking jrc0109 Maytag/Magic Chef/Admiral/Jenn-Air 3 October 16th, 2005 10:11 PM
Maytag MSD2454GR Side by Side Refrigerator Kent Maytag/Magic Chef/Admiral/Jenn-Air 1 September 17th, 2005 04:22 AM
Maytag Wide By Side - Compressor dies after 11 months pete_nc Maytag/Magic Chef/Admiral/Jenn-Air 4 August 16th, 2005 08:24 AM
