September 20th, 2007, 05:09 PM
Maytag MDB7600AWW Blinking '9'
I have a Maytag Dishwasher MDB7600AWW that displays "Rinse" light and the number 9 in the control panel. I assume this is a fault code. What does this code mean and how do I fix it?
Further I have trouble getting the unit to cycle. It will stop and revert to the error above.
September 20th, 2007, 10:50 PM
I couldn't find that model #. Try this link for error codes http://www.repairclinic.com/referral.asp?R=1265&P=176
Rick
OWNER RICK'S APPLIANCE REPAIR
REFRIGERATION SPECIALIST
September 21st, 2007, 11:37 AM
Rick, The Dishwasher is a Maytag Quiet 300 Series. I have checked all the Maytag error codes in the link and the closest seems to be that a '9' implies something with the door. But the door seems to work, unless if the switch doesn't work right, the error code shows. However the cycles are messed up from time to time and it's difficult to get a proper cycle.
Any Ideas?
September 21st, 2007, 04:41 PM
Still no luck with that model number. For some reason we have a hard time looking up Canadian models here in the lower 48. If this model uses an electronic control board, I would suspect that is where the problem is. Wish I could be more help.
Rick
September 24th, 2007, 09:23 AM
I found your model#, but I don't see "Rinse" light and the number 9 error code anywhere online.
If you take off your lower access panel below the door, you should see the diagnostics service sheet.
By jazzman_q in forum Maytag/Jenn-Air Reviews
Last Post: May 19th, 2009, 10:40 AM
By Memodos in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: July 10th, 2007, 07:33 AM
By chip718 in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: May 10th, 2007, 09:43 AM
By lccow in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: February 19th, 2006, 01:35 PM
By pete_nc in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: August 16th, 2005, 09:24 AM
