Old August 25th, 2005, 08:29 PM
toycode is on a distinguished road
Exclamation msd2756GES
Hi all, My 3 yr old frig & freezer work fine. Ice & water through the door works fine. My problems are frozen water puddle on the freezer floor & water leaking outside on the left back corner floor.It seems that the duct/grate on the rear freezer wall has a frozen water trail coming out of it,probably my puddle source.Any help would be greatly appreciated.
Thank you
Cody S.
Old August 25th, 2005, 09:00 PM
Sounds like the defrost drain has clogged up on you. You can take that rear freezer panel off and defrost the drain trough, then run something down the drain to clear it, I use 1/4" plastic water line tubing. Then run hot water down that drain , to make sure it flows down good to the drain pan.
Old August 26th, 2005, 08:08 PM
Thumbs up Killer diagnosis
You are on it !!! The drain was froze shut. Cleared it & I'm good to go.
Just wondering why it froze, There was no debris in the tube when I blew compressed air through it. Too cold or warm of a setting? Maybe while putting in groceries & leaving the door open too long ?
Thanks for all the help
Cody S.
Old May 23rd, 2006, 03:19 PM
GSPeed is on a distinguished road
Hello Jake. I too have the Maytag MSD2756GES, and noticed in the freezer side (left), when I pull out the last(bottom) basket, there is a greted vent behind. I heard a "sizzling" noise which led me to this location. Just behind the grate, I could see an orange glow which looks to be a coil heating up (similar to that in an oven). Cause of the noise, seems to be melting water hitting this coil! Is this normal operation, something to prevent condensation? Your time to review my post is appreciatd, thanks!
Old May 23rd, 2006, 07:45 PM
Yes, thats perfectly normal, the auto-defrost is just defrosting the evaporator coil behind that panel, the orange glow is the heater.
Old May 23rd, 2006, 08:27 PM
Thanks Jake! Your response and time is very much appreciated, thank you!
Old May 24th, 2006, 03:09 PM
Glad to help.
Help with MSD2756GES Msmithr99 Maytag/Magic Chef/Admiral/Jenn-Air 5 July 4th, 2006 11:57 AM
Side by Side model MSD2756GES leaks all the time mefrank Maytag/Magic Chef/Admiral/Jenn-Air 12 December 28th, 2005 11:58 PM
