November 18th, 2007, 09:49 AM
Maytag Quiet Series 300 Dishwasher - Control Panel Dead
I have a Maytag Quiet Series 300 Dishwashwer - Model Number MDBTT79AWS which is a little over 4 years old. It stopped working in the middle of a cycle and seemed to go completely dead, which also left quite a bit of water in the bottom.
I have checked that none of the breakers tripped, so it should still have power. Before yanking it out of the wall or calling a service tech I wanted to see if I could isolate the problem first. From previous posts in this forum the control board seems to go bad on these. However some people have a bad latch and some have a corroded ribbon cable. Is there a way to test the latch without taking the inner cover off the door, or some other way to narrow down the possibilities without a complete tear down?
Thanks for any assistance,
Marc
November 18th, 2007, 10:58 AM
Hi Marc,
Sounds like you might have a bad door switch (common). If they check good it might me a control board issue.
OWNER RICK'S APPLIANCE REPAIR
REFRIGERATION SPECIALIST
November 18th, 2007, 04:14 PM
Thanks for the quick response. Looks like it's just a bad wiring.
Before I got into the guts of the thing I wanted to make sure it was actually getting power. I found the conduit on the bottom after removing a couple of panels. As I was trying to work the probes up into the twist caps to check the power it all the sudden came to life.
I guess the wires had worked just loose enough to not make a solid connection. I don't think the installer used a cap big enough for that gauge of wire. So after a quick re-wire the dishwasher was back in action.
Thanks again for the help.
Marc
November 18th, 2007, 04:25 PM
Marc,
Glad you got it fixed. Happy holidays!
By kcarbs in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: January 2nd, 2012, 05:15 PM
By nursecarol1961 in forum Maytag/Jenn-Air Reviews
Last Post: November 6th, 2010, 05:07 AM
By QuietSeries300Lemon in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: June 19th, 2009, 10:43 PM
By NY Mike in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: February 17th, 2008, 04:45 PM
By Austinpowers in forum Sears Kenmore
Last Post: July 23rd, 2007, 07:35 PM
