Old December 29th, 2007, 08:24 PM
eric_1 is on a distinguished road
Default Maytag MLE2000AYW Dryer wont start
My dryer was running fine until today. After the third load, the dryer just stopped. The timer makes noise..but when I push start, nothing happens. The washer works fine.
Where should I start???
Old December 29th, 2007, 10:56 PM
It sounds like your thermal fuse went out, you have 2 on this model, I use a ohm meter to check for continuity when I test them. You can get a cheap volt/ohm meter at Radio Shack.
Make sure you unplug or turn the breaker off to your dryer first.
MLE2000AYW
Diagram#10 Part location#11 is your heater thermal fuse.
Diagram#11 Part location#10 is your main thermal fuse.
Old December 30th, 2007, 06:34 AM
Thanks Jake. I unplugged the unit for the evening and plugged it in again this a.m. Voila! It works.
Was this a one time event or is this likely to happen again? We were running the dryer for a while?
Old December 30th, 2007, 10:37 AM
Glad its working good again, maybe just a one time thing.
Its ok to run the dryer a long time if your doing alot of loads at a time, that shouldn't have any impact on the parts messing up.
Help Maytag Dryer MDE9206AYW No Start rvpeddler Maytag/Magic Chef/Admiral/Jenn-Air 9 July 23rd, 2007 01:42 PM
Maytag Performa Dryer does not start carerob Maytag/Magic Chef/Admiral/Jenn-Air 1 June 29th, 2007 11:51 PM
Maytag dryer will not start reverend saveabuck Maytag/Magic Chef/Admiral/Jenn-Air 3 April 18th, 2007 08:12 AM
Maytag Performa Dryer Won't start cheapkelly Maytag/Magic Chef/Admiral/Jenn-Air 10 July 18th, 2006 03:57 PM
Maytag Dryer LDE7304ACE, won't start dorton Maytag/Magic Chef/Admiral/Jenn-Air 1 March 31st, 2006 12:20 AM
