Old March 11th, 2008, 09:08 AM
tshurd is on a distinguished road
Default Jenn Air Oven turns off during preheat
My Jenn Air single wall oven shuts off during the preheat cycle. I can post the Model Number when I get home. Here are the symptoms:
  1. When entering bake, broil, convection or clean, the oven asks for the temp (or time in case of clean)
  2. I can set the temperature and the preheat indicator is shown on the display
  3. The appropriate element(s) heat up
  4. Within several seconds, a relay clicks off (sounds abnormal, like a real quick buzz)
  5. Several seconds later the oven display goes back to the time only
How I get it to work in bake mode (but will also work for other modes):
  1. Press Bake
  2. Enter Temperature
  3. When I hear the abnormal relay click/buzz, press Bake and set temp again
  4. I have gotten good at distinguishing between the good relay click of the upper and lower element relays (duty cycle dependent on mode)
  5. After fiddling for about 5 minutes with this, the oven gets up to temp and will work fine
I have the wiring diagram and suppose the problem could be the main PCB relay (DLB). But I also suppose it could be the control board that tells the relay to close.
The sensor checks out okay.
I haven't jumpered the high limit switch.
Questions:
  1. Suggestions on how to troubleshoot further?
  2. If it is the relay, any ideas on where to find a replacement part? The Part Number is T91P1D22-18F07
Old March 11th, 2008, 09:54 AM
Yes, we would need the model# to check and see if we can get you a service manual for it online.
Its probably going to be very hard to locate the relay itself, you'll likely need the complete board assembly.
Old March 11th, 2008, 02:23 PM
Model Number is W2780.
Old March 11th, 2008, 11:13 PM
There should be a B or B-C or W or W-C after the 0 at the end of your model#.
I couldn't locate a service manual online.
Here's the relay board for your model:
Manufacturer part#Y04100260 is RepairClinic item#1242519
Y04100260
Old March 12th, 2008, 07:37 AM
The Model Number is W2780W.
I'm trying to figure out how to test whether the relay is the culprit without spending $150 on a new board.
Can you tell what the coil voltage is on the DLB relay so I can find a suitable 30A 240VAC substitute?
Old March 12th, 2008, 09:26 AM
I wish I could, but without a wiring diagram/repair manual for this unit, I don't know.
Jenn Air Oven SVD48600B continuous fan Deb Remkus Maytag/Magic Chef/Admiral/Jenn-Air 11 January 18th, 2009 10:04 AM
Jenn Air oven door not closing wakeappliance Maytag/Magic Chef/Admiral/Jenn-Air 4 October 21st, 2008 03:19 PM
Jenn Air oven shuts off. nyrend Maytag/Magic Chef/Admiral/Jenn-Air 1 September 28th, 2007 11:19 AM
Jenn Air Oven model #D146-C sim Maytag Brands Forum 0 September 18th, 2007 04:04 PM
Jenn Air Wall Oven With Fault Code 1 AFH Maytag/Magic Chef/Admiral/Jenn-Air 9 November 3rd, 2006 09:52 AM
