Old March 20th, 2008, 08:08 AM
twm40 is on a distinguished road
Default Neptune(MDE4000AYW)-Heat only during timed cycle
I have a Neptune electric dryer, model #MDE4000AYW. I noticed that the normal intelli sense dry cycle and the wrinkle free cycle doesn't heat up. It started about 3 days ago.
If I set it to the timed cycle it heats up and dries just fine to completion.
I also noticed that the moisture sensor will only light up on the timed cycle but not when the other two drying cycles are used. The sensor appears to be functioning properly on the timed cycle.
I have checked the vent and all is clear. The element seems to be fine since it always works on the timed cycle.
Where should I go from here?
Tim
Old March 20th, 2008, 05:46 PM
Bambiblaster's Avatar
Would have to be a bad timer.. nothing else controls it
Old March 20th, 2008, 09:58 PM
Yes, I agree with Bam, its likely the timer.
Whats the serial# of your dryer? as they make 2 different timers for your model.
Old March 20th, 2008, 10:30 PM
Thank you for the repies. The serial number is 10624775WD. Can it be something as simple as bad contacts that could just be cleaned or is this a sealed/electronic type part requiring complete replacement?
Tim
Old March 20th, 2008, 11:34 PM
Thanks Tim,
The timer is sealed . You would just need to install a new timer.
Here's the timer for your model you can order:
Manufacturer's Number: 33001730
icon
icon
icon33001730
Kenmore 665 - dead buttons and long cycle time buffaloguy Sears Kenmore 1 February 7th, 2008 10:31 AM
Heat won't shut off if door opened; no cool down cycle arthuritis Sears Kenmore 5 May 8th, 2007 09:24 AM
Maytag dryer trips breaker when turned on heat cycle miketharris Maytag/Magic Chef/Admiral/Jenn-Air 2 January 28th, 2007 08:24 AM
Kenmore dryer: how long should heat cycle? ffspiel Sears Kenmore 5 April 8th, 2006 08:16 AM
Kenmore - buzzer doesn't quit on timed cycle only tinkermon Sears Kenmore 5 June 22nd, 2005 07:58 PM
