Old May 20th, 2008, 06:16 PM
kjr232 is on a distinguished road
Default Noisy In Spin Maytag Washer
I Am Working On A Maytag Washer Model Lat9420aae. Complaint Was Noisy Spin And Water Leak At Tub Bearing. I Replaced Mounting Stem And Boot Seal Kit And Tub Bearing. Water Leak Was Fixed. But Machine Is Still Noisy In Spin. I Noticed That Sound Is Coming From Either Brake Rotor Bearing , Radial Ball Bearing Or Possibly Both. I Have Never Replaced A Radial Ball Bearing. Any Tips Would Be Greatly Appreciated.
Old May 20th, 2008, 09:22 PM
ApplianceJunk's Avatar
I doubt the sound is coming from the break on that model.
Breaks most often are only noisy during the stopping of the spin cycle.
I would replace that other bearing.
John Pahl
ApplianceJunk.com
ApplianceDigest.com
Old May 20th, 2008, 11:55 PM
Yes, I agree with AJ, Its more likely the spin bearing above the brake assembly.
Here's the one for your model, there's also a link for the brake removal tool:
Manufacturer part#22003441 is RepairClinic item#893728
This shows you how to remove the brake assembly:
Old May 23rd, 2008, 08:05 AM
Thanks For The Info It Was The Bearing In The Top Of The Brake Package. Water Had Gotten Into It And Rusted It. That Was A First For Me In Finding This Bearing Bad Thanks For All The Help. Kjr232
Old May 23rd, 2008, 12:40 PM
Sounds good, glad you found it was the top bearing above the brake package.
Maytag Dependable Care Washer Squeal/Sqweak on Spin Start ggallant Maytag/Magic Chef/Admiral/Jenn-Air 7 April 9th, 2007 01:43 PM
Need Ideas For Troubleshooting Noisy Maytag Washer kc27 Maytag/Magic Chef/Admiral/Jenn-Air 4 January 7th, 2007 03:41 PM
Maytag PAV1000AWW washer won't spin unless helped erasmusk Washers 5 November 26th, 2006 10:37 PM
Maytag Performa Washer will not spin jskaldorf Maytag/Magic Chef/Admiral/Jenn-Air 5 August 1st, 2006 04:23 PM
Kenmore HE3T Washer - Noisy Spin Update info carolynnchase Sears Kenmore 1 May 11th, 2006 12:22 PM
