Old June 19th, 2008, 05:57 PM
tomingh is on a distinguished road
Default Jenn Air gas range JDS9860AAP
I'm getting no spark in one of the burner modules. When I switch sides with them, it still doesn't work but the other one does when placed in either location. So that must mean the problem is in the module (or component) itself, right? The only parts I see that appear to have something to do with the spark are the spark module and the top burner ignitor. Is the problem more likely to be one rather than the other or could it be something else all together? Thanks for your help. Tom
Old June 19th, 2008, 06:49 PM
Hi Tom,
Sounds like its possibly your spark(burner) switch.
Page 24 explains how to access it:
http://www.servicematters.com/maytag...s/16026016.pdf
Which one is giving you the trouble, the right or left one?
Page 2 here tells you how to test it:
http://www.servicematters.com/maytag...s/16026780.pdf
Old June 19th, 2008, 09:36 PM
Thanks for your help. The problem is with one of the cartidges -- it doesn't work no matter which side I put it on while the other one works on either side. Is there a part in the cartridge itself that may need to be replaced?
Old June 19th, 2008, 09:51 PM
So the cartridge has 2 burners in it? Front and Back? Both don't work at all?
But you put the other cartridge in from the other side it works?
Your cartridge should have a model# on it, please post that so I can check.
Old June 20th, 2008, 03:36 PM
You're right, the cartridge has 2 burners in it - Front and Back. They will light manually but not via a spark because that cartridge doesn't click or produce a spark. But when I put the other cartridge in from the other side it works just fine. I looked but can find no model number on the outside of the cartridge. The serial number for the range is 20554602ET if that is of any help. Thanks, Tom
Old June 20th, 2008, 07:44 PM
Ok, #10 here is your spark(burner) #21 is your burner igniter, #20 is the burner.
If the other cartridge is working in the place where the other cartridge was, then we know that its not #10, so it would have to be the #21 igniter: Manufacturer's Number: 74004053
icon
That #20 burner should just twist to remove.
Also check your wiring in your cartridge to make sure the wires are fine.
Jenn Air jes8850bas range nhicknell Maytag/Magic Chef/Admiral/Jenn-Air 4 March 2nd, 2010 05:40 PM
Jenn Air gas range goes out if vent is on Dave Miller503 Maytag/Magic Chef/Admiral/Jenn-Air 5 March 13th, 2008 11:21 AM
Can Jenn Air Pro Series Range be converted? wsnelms Maytag/Magic Chef/Admiral/Jenn-Air 2 September 25th, 2007 06:57 AM
Jenn Air range JGR8750ADW sadiedog1 Maytag/Magic Chef/Admiral/Jenn-Air 0 February 11th, 2007 03:05 PM
Problem with Jenn air down draft slide in range. jerr462 Maytag/Magic Chef/Admiral/Jenn-Air 6 January 9th, 2007 09:36 PM
